Question about AEG Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next and then these flashing lights and no start. these flashing lights not described in manual
  • 9 more comments
  • peckhambog May 20, 2008
    The machine always went straight to all lights flashing when switched on [not only start light illuminated alone].
    We had to shell out £100 for someone to fit a new 'programme board'.
    At least the machine is operational again.
    I bought a second hand Dyson CR01 Memory Flow in the interim and that is serving very well. Fantastic capacity. It's four years old. Dyson replaced the drum and a couple of peripherals last year for the previous owner.
    Does anyone know the life expectancy of a Dyson serving a young family of nine persons?
  • peckhambog Jun 24, 2008
    I am unable to test the 2nd contribution, because as I said, I have already shelled out £100 to an engineer who fitted a new circuit board.
  • Anonymous Mar 12, 2014
    machine is stopped. wash and rinse lights are flashing. tried unplugging for awhile and plugging back in to no avail.
  • Anonymous Mar 15, 2014
    Not starting to wash. Red lights lit up on wash and rinse. Bosch 1200 washing machine.
    wash smart machine wash light flashing and machine won't start
  • Anonymous Mar 18, 2014
    rinse problem
  • Anonymous Mar 22, 2014
    on/off and rinse hold lights flashing and wash cycle not functioning
  • Anonymous Mar 23, 2014
    Stops washing start light and washing light flashing
    cycle would not complete final spin. wash, rinse & spin, final spin lights on, door locked light flashing
    cycle wont complete final spin wash, rinse & spin, final spin lights on, door locked light flashing. pressed started/cancel button for 3 sec cleared lights and door opened.restarted cycle again , started as normal for 10 sec then stopped, wash light on and door locked light flashing
  • Anonymous Mar 27, 2014
    When I load washing machine and set programme and start, the frost light flashes 5 times and cycle won't start. What could be the problem?
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • carsija1 Apr 07, 2010
    My OKO Lavamat 76669 UPDATE washing machine stoped working again today and I have tried to reset it. I had to hold both the Pre wash and Soaking buttons and turned the rotary knob clockwise from Off position to the Energy Saving position and it is working now.
Can you switch back to off - then to orginal programme - only the start light may show - what i did then was press all of the 4 button for rinse, spin short wash and held them in place - fro upto 10 secs - machine seemed to reset itself and it worked
Posted on May 19, 2008
6ya staff
SOURCE:
AEG OKO Lavamat 74640 update wont spin. Pump and rinse works ok but doesn't spin.
  1. E52 is a motor fault, i.e. motor not turning or tachometer is faulty. It is most likely that the carbon brushes are worn out and need replacing. These are readily available online
Nov 12, 2016 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
1,321 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
jimorris77
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
