Question about Dryers
McCulloch 3200 won't run
Twelve year old, lightly used McCulloch 3200 14'' chainsaw won't run. It started after a few pulls and ran for about 15 seconds, Then died. Now...nothing. Sat in storage for about 5 years. Has original spark plug, which looks very good. Removed and cleaned. Used a spray carburetor and choke cleaner in carburetor. Drained old fuel and replaced with brand new.Would like to avoid removing and rebuilding carburetor, if possible. Thanks!
  • 251 Answers
Sorry but really does sound as its only ran for 15 secs on the choke cleaner , we usually change the fuel filter ( thats inside the tank , use a hooked piece of stiff wire to pull it up ) , you will likely need to do a full strip and clean of the carb and fit a new diaphragm the small needle valve may well be stuck into its seat , also watch for the fuel line being perished , and very important , make sure its full of of chain lube oil and pumping correctly ( do this before you even fit the chain and bar )and the chain is tensioned correctly and the clutch and chainbrake operates properly
Posted on Nov 18, 2009
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
McCullough chainsaw won't start
if it's a old saw..The seal goes out on the crank next to the clutch,it's called a grease seal, it loses the suction needed to pull fuel in to the engine, can be a tricky one to replace, but will spark a old saw back to life. You may want to replace both crankshaft seals ..First try a few drops of gas down the carb, if it pops off you know it's a fuel issue
Nov 14, 2013 | McCulloch Quality Mcc1435a 14" Gas 35cc 2...
Mcculloch chainsaw mac 3200 manual
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 15, 2012 | McCulloch Garden
Fuel mix
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Aug 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I need to know the spark plug gap on my McCulloch 14" 3200 series
0.020" should work well and is common on most saw engines. Good luck!
Jun 16, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch chain-saw fuel-oil ratio 3200
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 14" electric-will NOT run
check the carbon brushes in it. open the cover of motor you can see two pc. of carbon touching the armature. If that become short it need replacement
Jun 29, 2009 | Garden
Need a manual for McCulloch mac 3200 chainsaw
MS1432 seems to be a good match for the mac 3200 (at least the Mac 3200 I just aquired from Pawn Xchange is identical to the MS1432 that was swiped from me last year by an *EX* friend) - PDF here:http://lawnandgarden.manualsonline.com/manuals/mfg/mcculloch/ms1432.html?idRes=5629277
(Yeah, I know, this is an old question but, it may help the nest person needing a manual)
Apr 04, 2009 | Garden
Dryers Logo
147 people viewed this question
Top Dryers Experts
