Question about Magic Chef CGS3760 Gas Kitchen Range
MY MAGIC CHEF OVEN GETS UP TO THE SET TEMPERATURE AND THEN STOPS WORKING. wHY? aLSO, WHEN STARTING UP THE GAS SEEMS TO ACCUMALATE BEFORE IGNITING CAUSING MINI-EXPLOSIONS
  • 11,896 Answers
Sounds like pilot light or internal rod inside pilot is corroded or dirty and not keeping pilot at the correct temperature. An oven temp sensor could give you similar problems. You can get parts and manual at repairclinic.com or partselect.com
Posted on Nov 18, 2009
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Tip
Magic Chef Gas Ovens
If your Magic Chef gas oven doesn't light, most likely the oven igniter (rectangle style) is the problem. The igniter may glow and appear to be working, but doesn't get get hot enough to open the oven bake valve. I recommend replacing the igniter first.
on Mar 21, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Whe i set the oven to 350 it has an F3 and wont light. This is a magic chef gas pioltless stove
Hi ttommajor,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Oven Won't light anymore
when your oven was working did it "click" to start? or do you have a glow bar style ignitor. if yo u have a glow bar ignitor chances are thats the issue. if your oven would click to light then there might be a few issues on that but just like you top burners you should be able to light the oven with a long match and or barbecue lighter
Nov 11, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef CGS3760 Gas Kitchen Range Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
