Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Water not drainge in my kitchenaid dishwasher/KUD101FLSS3
  • 126 Answers
There is probably something stuck in the pump. Take the bottom kick plate off, and see if the pump is trying to work.
Posted on Nov 19, 2009
Kitchenaid dishwasher KDC-18 works but the water does not get hot just cold. Any solution?
Dishwasher must be connected to a hot water line in order to work properly. Also, it often requires a good deal of time for hot water to make its way from the water heater to the dishwasher. If the dishwasher is located under the kitchen counter, turn on the hot water in the sink until it runs hot, then start the dishwasher.
Many dishwashers have a built in heater, but hot water should be initially fed into the dishwasher through the water inlet in order for it to perform properly.
Mar 17, 2013 | KitchenAid Dishwashers
The dishwasher is not drainging
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 04, 2010 | Frigidaire Dishwashers
Drain cycle will not turn off - even when all the water has been drainged. Also stays on when opening the door.
pull the machine out and tilt it back, water may pour out from under the machine, if it does, it indicates that the anti-flood device has actuated, thats why the machine is continuing to drain constantly. leak some where underneath is the problem.
pallesappliancerepairs.com
Feb 03, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Kitchenaid KUD101FLSS3 Won't Drain
did you take the knock-out from the garbage disposal. It is located in the line where the drainhose is connected.
Mar 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
Jan 13, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Jan 02, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
KUDS01FKSS dishwasher not cleaning
One thing to check is soap usage. Newer dishwashers use less water and require less soap. Too much soap will redeposit on dishes. Try halving soap usage. Also run hot water in sink until it gets hot before running dishwasher. I have a Whirlpool. Same thing. Works great. If your water is hard add more detergent.
Sep 01, 2007 | KitchenAid KUDS01FKSS Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
207 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
