Recently my washing machine has been giving off a putrid eggy smell when on any program. I clean inside the drum, the drawer ect often. i have checked both inside and outside drains and cleaned them. i was also informed to use white vinegar in the machine while on a wash cycle. All this to no avail. Please help me solve this problem.
  • 251 Answers
It may well be stuff from your sink drain trap syphoning back into your washing machine
sounds like you need an anti syphon valve to be connected in line with your washing machine waste water outlet
Check that hose discharge from washing Machine loops up above the minimum height as specified by the machine manufacturer and at least to the underside of the work top for an inset sink before connecting into the sink trap.
http://www.wickes.co.uk/invt/420182
Posted on Nov 19, 2009
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
My washing machine smells inside the drum. It makes the clothes smell and even though it has been on a self clean cycle the smell is still there. Please help.
Clean your machine by using a cotton wash at 85'C without anything in it, and with no detergent.
Also, empty the coin-trap at the bottom left (front of the machine).
Also, remove the detergent drawer, clean by hand. While the drawer is out clean the dispenser area with mildew cleaner.
You can also try using Sodium Metabisulphite (see a homebrew shop). Avoid using bleach as it damages the stainless steel.
In between washes you can leave the inner door slightly ajar to allow it to dry out between washes.
Apr 02, 2011 | Dyson Memory CRO1 Front Load Washer
The last couple of washes our conditioner tray the middle section isn't draining anymore
take drawer out give it a big clean ...all the holes ect .. clean inside machine part too.. job done :
Feb 27, 2011 | Washing Machines
Does the hotpoint auarius have a filter that needs cleaning over the past two weeks or so the machine has started to smell the drum and soap drawer are both spotless
It does, but our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attaching from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetrre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. HOWEVER. Before you do this, if you are getting smells, first take 3 DISHWASHER tablets, throw them in an empty washer and put it on the hottest whites cotton program you can. Modern biological powders use bacteria to "eat" stains and when they get trapped in the machine, they can smell. Dishwasher tablets are made to wash and to KILL bacteria. It may help. Its a good thing to do anyway every now and again and it may save you a fruitless job dragging the machine out for no reason.
Jun 04, 2010 | Hotpoint Aquarius WF220 Front Load Washer
I have a bosch washing machine and over the past couple of days the fabric conditioner wont drain i have recently cleaned it . it all seems to have started since then i also bleached the drum because i...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually. Hope you've checked out & cleaned your filter.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Dec 19, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Fabric softner does not disperse, a smell comes into sink.
Remove the drawer and thoroughly clean out the drawer. They usually have a syphon mechanism which gets blocked. On many, you will find a section of the softener compartment can be removed. Make sure there are no traces of old softener. The eggy smell is due to the enzymes in the detergent not being properly flushed from the machine. Check the waste water pipe is clear of debris and clean out any filters (not all machines have these) - normally under a cover at the front of the machine near the floor. While you have the detergent drawer out, it would be worth cleaning the area as it often gets clogged and covered in detergent or softener, and can block the water feed holes.
After all this cleaning, run the machine on a hot was with no detergents/softeners or laundry in it, to flush it out.
Jan 07, 2009 | Whirlpool Washing Machines
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Kenmore front loader drum grinding
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Sep 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
