Question about Cobra 150 GTL DX Base CB Radio
Fuzzy or static tranmit
I have a 150 and the modulation is fuzzy I can here it in the talk back. I have tried 4 diferent miks, echo on and off talk back on and off tryed everything I can think offf any ideas Thanks Jarrod
  • 3 more comments
  • Wizzardmxz Jan 10, 2008
    Not very high like a 1/1.5 give or take??
    I think it swings a lot.
  • Wizzardmxz Jan 11, 2008
    Ok I'll have to try it in the morning thanks.Keep the ideas comming incase thats not it.
    Thanks
  • Wizzardmxz Oct 03, 2010
    Yep if I keep the swr's low it works great.
  • 589 Answers
I know this may sound like an odd answer, but what are your SWR's? If they are high, you will experience some WEIRD audio problems.
Posted on Jan 10, 2008
  • 1 more comment
  • brian c
    brian c Jan 10, 2008
    Hmm. I've run mine as high as 2 with the :ehem: box on..
    I know if your radio has a ton of "swing" this will happen. Does the wattage it deadkey real low and swing high?
  • brian c
    brian c Jan 11, 2008
    Yah, thats the problem. Check the SWR's at the peak (yell into it)... I bet they're through the roof.
  • brian c
    Will do. I will go outside and dig out some of my old notes on these things.
Iphone 4 screen has gone fuzzy and blurry
time to replace you digitizer and screen. We do it for 99.95 with return shipping.
Feb 18, 2014 | Apple iPhone Smartphone
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
Echo and noise on calls
Reconfiguration won't help. The problem is on the open communication line and only the provider of services can assit you in fixing the problem.
Apr 17, 2013 | Cisco SPA400 Internet Telephony Gateway...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Model 34pw8520 picture got fuzzy, then fuzzy, clear, fuzzy clear, then went blank (black). Picture tube? how much to repair?
sounds more like the flyback. What is the chassis number of your set. The flyback if thats what it is would cost under 50 if you replace it yourself maybe 150 if a shop does it. But post the chassis number as the chassis number would make it easier to try to figure out if its the flyback or not.
Mar 24, 2008 | Televison & Video
Fuzzy Screen
you have a defective control module
Oct 18, 2007 | Polaroid FLM-3232 Television
My send is fuzzy and hard to understand. I recieve just fine
Perhaps you need to check your SWR? See the following link: http://www.transmission1.co.uk/modules.php?op=modload&name=News&file=article&sid=11
Jul 26, 2007 | Cobra 19 DX IV CB Radio
ALL MY CHANNELS HAVE A BLACK PICTURE & FUZZY, PLEASE HELP
first off how good are you with a solder iron ? beside the obvious rf connector problem these set's had problems with bad solder connections within the tuner itself. google( sam goldwasser repair faq) for the solder template.
Jun 10, 2006 | RCA F27252GY 27" TV
Cobra 150 GTL DX Base CB Radio Logo
61 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
