Question about Panasonic PT-50LC13 50" Rear Projection HDTV
HOW TO ACCESS THE LAMP IN PANASONIC PT-50LCX64
  • Panasonic Master
  • 5,138 Answers
It should be behind a small opening on side of TV or Back Look for a part of Back with 4 screws holding Like a small opening to TV when you see the Lamp it should have 2-4 screws holding it in Place 2x2 or 4x4 they are not very big Some sets you may end up just removing the whole bottom back off.
Posted on Dec 09, 2009
How do you get to the power fuse on a PT-50LCX64 panasonic rear projection tv
Follow the power cord inside the set---be aware precautions and care need to be taken when opening the set--easy to damage screen etc if not done properly.
In this set usually not a fuse if dead unless no power light--nothing at all.....
Apr 24, 2012 | Panasonic PT-52LCX66 Projection Television
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
WOULD LIKE TO GET A WIRING DIAGRAM SO I CAN FIND OUT THE PART NUMBER FOR A CERTAIN WIRE THAT IS BROKEN. THE MODEL NUMBER IS: pt-50LCX64. THANK YOU
You can purchase one for $12.95 from the link below:
http://service-manuals-schematics.com/purchase.php?id=Panasonic+PT-50LCX64+Service+Manual+%2F+Schematics
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
A week ago when I turned on the power my Panasonic PT-50LC14 t.v. power button blinked green for a very long time, then began blinking red & the lamp light blinked red once every 5 seconds. I read the...
To be honest to you, that kind of TV is not worth repairing.Better buy a new one and dont buy that kind of TV LCD projection .there is a problem on the design of this kind..This is not durable..IF you still decide to repair it youll gonna run the same kind of problem...Sorry for that.... Thanks for using FIXYA. please rate my help.GOD BLESS!
Jun 15, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
