Question about Whirlpool 24 in. GU980SCG Built-in Dishwasher
I have whirlpool dishwasher 2007. everything works but the rinse cycle..it makes a gurgle noise and spits out a little water and thats it..what could the problem be?
    President:
  • Whirlpool Master
  • 1,922 Answers
Check the waste food drain sump below the screen,then chk the pump in the sump area,then chk that the house drain is clear where its hooked to
Posted on Nov 19, 2009
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
My whirlpool dishwasher will not start. It beeps, drains & flashes Err4 on the screen.
If you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completely) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone!
Sep 28, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Loud squeeling sound during wash cycle, and sanitary rinse
If you’re hearing a fast knocking sound, then it is your motor going bad. This will result in an LE code and the unit will no longer work as this gets worse.
You can get a replacement sump assembly that has the motor and all new sensors to resolve this issue.
Good Luck.
Jul 23, 2010 | LG LDS4821BB 24 in Builtin Dishwasher
My Quiet Partner III dish washer gets very noisy while filling up with water at beginning of rinse or normal wash cycle. That noise lasts for about 1 minute upon starting only. Would it be a faulty...
yes its a bad inlet valve. sometimes you can turn down the house valve the washer is connected to a little to stop the noise.othe then that replace the inlet valve.
Feb 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher makes noise during drain cycle
This really isn't a solution, but I found info on Whirlpool's site that the noise could be caused by the disposer and food or something in it. They said to use it a few cycles and see if the noise goes away, so that's what I'm doing. I always rinse dishes before going into the dishwasher, so don't really think there could be food particles etc. causing the problem, but we'll see. Not anxious to pay for a possible solution unless through a repair person. Thanks for your reply.
Jun 19, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Strange noise from my Bosch Dishwasher SHU66C02UC/14
It just the pump noise. Since your dishwasher works properly you can ignore this noise.
Sep 09, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
200 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
