Question about Maytag Performa PAV2200
Maytag A408 washer- needthetimer part off for new
How do I get the timer part off so I can put the new one on?
  • 11,896 Answers
Look at the link: http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153000&brandID=...
pop the front chrome cover off the knob, slide the spring clip off the timer shaft, remove the spring and bezel, then remove the dial indicator. Reverse this process to reinstall the knob.
Posted on Nov 18, 2009
I have a maytag mtw5770tq0 I just put a new timer on water will fill but will not start washing thanks Dennis
This could be a lid or door interlock failure depending upon the type of washing machine.
Jan 10, 2015 | Maytag Washing Machines
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Washer timer advances all the way to off, but never stops. washer just keeps spinning. new timer is not the solution.
IF THE TIMER HAS BEEN REPLACED AND SOUNDS LIKE IT'S WORKING THERE HAS TO BE A WIRE OUT OF PLACE. THE TIMES HAS CONTACTS THRU OUT THE DIAL TO PUT MACHING INTO DIFFERANT CYCLES AT THE STOP CYCLE THE WASHER SHOULD STOP IF THE CONTACTS ARE GOOD
Sep 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Where can purchase a new timer for my maytag atlantis washer.cost
Hello I would have to know the model number to give you a cost on the timer, You can buy a timer from www.repairclinic.com. Hope this helps :)
Jul 16, 2009 | Maytag Washing Machines
Maytag washer will not agitate
ckd wiring connections motor and timer? if they look ok suspect timer ..motor contacts in timer may be shot
May 01, 2008 | Washing Machines
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag sav571eeww
put a new timer in it
Jan 26, 2008 | Maytag SAV571EEWW Washer
Maytag mav7600 agitator works and don't
Look at timer plug on harness for pins that are sticking out from side of timer plug, away from timer. See if they are all in the same amount. Sometimes one can work its way out so it won't make a good contact. Push in to plug if you find one.
Nov 14, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
