Question about Brother MFC 210C All-In-One InkJet Printer
My mfc210c displays an unable to clean message, what do i do
    President:
  • 787 Answers
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 19, 2009
Unable to Clean ! Message on Display Printer Model MFC210C Installed new Cartridges from Brother
Are you using a generic.. That is your problem. Gerenics have not perfected their products for brother ,because I had a problem and I had to go back and buy OEM and my machine works fine
Aug 05, 2010 | Brother MFC 420CN All-In-One InkJet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean,need code to reset MFC210C, I
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother Network Ready All-In-One InkJet...
Unable to clean,check manual
LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
thanks.
Jul 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error messaage "unable to clean" on a MFC210c
There should be a number with the error, if it's 46, you need a new ink flushing box. You won't be able to fax until you clear the error.
Jul 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C keeps displaying unable to clean messasge
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Was this solution helpful? Show your Appreciation by rating it:
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC210C without warning message displayed "unable to print" trouble shoot and routine maintenance chapter in user guide. Have followed the guide for cleaning etc, have installed new usb...
Waste ink pads are most likely full. If you are keen on the device you will need to strip it down, remove and clean the waste ink pads located in a chamber just behind the cartridge chamber, refit the pads and re-assemble the machine. Then you will need to go to google or similar search engine and locate the purge reset key code sequence for your machine. When you have done all that your machine will PROBABLY work - but no guarantee :-)
Sep 29, 2017 | Brother Office Equipment & Supplies
Cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
Feb 19, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
297 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
