Question about Pioneer VSX-D511 Receiver
Display is out. no sound. otherwise perfect LOL When powering up I hear 1 click - its the black relay on the left by the 110v section. All 3 fuses on the mainboard are fine. Where to start!?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Try this:
The display is dark or off.
• Press FL DIMMER on the remote control repeatedly to return
to the default.
let us know if more troubleshootig is needed.
here is the link to your manual:
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50031operating_instructions_VSX-D511_20024312547330.pdf
Cheers!
Posted on Feb 15, 2010
Power windows not working
1 does the led's light up on the master window switch [drivers side] 2 when you rocker the drivers side down can you hear a audio click down under the steering wheel. the i/p fuse panel is down there where you rest your left foot.3 power is from battery saver relay to master ins. relay to one touch window relay. this is the one you should hear click. the back side of this fuse panel calls out the locations down there. the owners manule also helps some.4. if you take the interior door cover off remove the screw on extenstion on door lock and one screw under plastic button where you pull the door shut.arm rest support bracket. the rest is held in place with snap in plastic buttons [christmas trees like]. the door latch unlock should slide out of the opening when you slide it froward.there are 4 male/female electrical connections, 2 to the master door switch.one to the power/heated mirror, 1 to power locks. 5. don't unsnap them yet.with a test light you can check for battery voltage. on the master door switch the blue/black tracer wire should be hot[12 volt dc]. at all times. put one end in the backside and the other to a bolt or rivet on the door. the light should come on.next with one end on the blue/black tracer and one on white/black tracer rocker driver side up/down switch, the light should come on.there are only 13 wires on the master window switch 2black wires are ground, 2blue/black tracer[hot] 1 red/blue tracer should be [hot] when you unlock the window lock rocker switch.know the passanger and back seat switches should work. switch it to lock and they should only work from the driver side master switch.the 8 wires left are 2 for each window one up one down.try this with a friend it makes it easyer. good luck doug.
Sep 10, 2012 | 1997 Ford Taurus
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
Sep 24, 2009 | Sony STR-DE525
No dash lights windows wont go up or down car wont even attempt to start could it be the fuses dealing with the starter relay cause i hear a clickin sound from the fuses underneath the wheel left side with...
Relays will click when they're getting power to initiate them. They may not be getting power from their main source. Check under hood for a set of fusible links, if all your small fuses in fuse box are good.
Aug 09, 2009 | 1997 Nissan Sentra
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Bigscreen won't turn on at all- no LED's, no sound/vid, get a relay click though
It might be the relay itself, you sound tech savy have you tried testing the transformer and various other main board componets?
Apr 25, 2009 | Televison & Video
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
Pioneer VSX-D511 Receiver Logo
74 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
