Question about TruTech PLV16320 Television
The red lite goes off when you power the unit up...but stays black....nothing happens....have pluged and unplugged several times.....no difference
  • 979 Answers
Good day sir, hi, as I see it, the red light is on stand by, and turning on the TV nothing happens, This could be traced from a failure of the power supply board to the mainboard. This diagnostics should be done by a qualified service personnel and should not be performed by a novice. The process is to locate the problem board, first replace the power supply board, then test, if the board respond then good, but if not, replace the main board which controls the sound, LCD, controls and the likes. replacing the two boards are costly, so I suggest you take it to your dealer for proper advice on your TV. if its under warranty, much better. they will replace the entire tv.
Posted on Nov 18, 2009
Testimonial: "Thanks much for the help on this...very fast response"
How do I get My RCA TV to power on?
Hi Cathy,
There is nothing you can do about it yourself. Please consult some local TV Tech.
Jan 23, 2016 | RCA Televison & Video
Green lite will not on . when unit is pluged in
press reset+power for 20 seconds, then release reset ank keep pressing power, it will turn on for 10-20 secs, in this time you must connect it to the pc. run tomtom home and make the upgrades that the program sais. must help.
Apr 20, 2011 | Tomtom One XL GPS Receiver
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Will not turn on
It sounds like the VCR ate the tape. When this happened to me (with a different brand name) I took the top off of the unit and carefully removed the cassette and DVD.
USE CAUTION WHILE DOING THIS AND DUH!!! UNPLUG THE UNIT BEFORE REMOVING THE SCREWS!!!!!!
You should unhook the unit from the tv connections and take it to the table or other flat surface. While it is unplugged!!! remove the screws and remove the top of the unit. BE CAREFUL not to remove anything else!
Simply remove the cassette and DVD. Then plug in the power and make sure it comes on properly. Open the DVD tray to make sure it works also.
Then reconnect the unit to your tv and ENJOY!!
Trust me, it works... I've done it several times. I cannot promise that your problem is an eaten tape... but it sounds like it and when this happens 90% of the time, it triggers the unit to "turn off" due to a problem. Therefore, you turn it on and the unit turns itsself right back off!
I believe this will work for you :)
Jan 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
Red light stays on when powered,won't turn on.
Don't have a solution. Cannot turn red lite off with remote or manual operation.
Oct 25, 2006 | Cyberhome CH-DVD 300 DVD Player
TruTech PLV16320 Television Logo
269 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
