Question about Carver PM950 Amplifier
T12.5L 250V fuse for carver amp
T12.5L 250V fuse has blown, my fault, what is the value to replace this fuse and what is the T1, a part number or some thing I can't find a 12.5 amp fuse, glass 5mm x 20mm so I'm thinking it's a 2.5 and T1 is just a part number or something. logo on the fuse is a W with an x on top center with a circle around the x
W the whole thing.
  • Carver Master
  • 5,349 Answers
Yes T1 stands for fuse One. The fuse is a 2.5amp at 250volts. The only thing you need to work out now is if it's a Quick blow or Slow Blow type. Sometimes you can still see the remains of the wire that's gone on the old one. This is your best clue to it. If it is a single wire it's a Quick, if you can see a coil then it's the other.
If in doubt use a Quick blow type.
Posted on Nov 23, 2009
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
Sep 12, 2014 | Roland Cube Street - Battery Powered...
Where can I get a Type T 6.3 AH 250V fuse for a K3000FX 300Watt Keyboard Amp?
Start with a 5 amp fuse and see if that holds. If it doesn't go to 10 amp. If that pops, you will have a power supply or amplifier fault. Good luck
Aug 12, 2014 | Behringer Ultratone K3000fx 300w Keyboard...
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
Fuse
If you look closely a the metal ends of the fuse you`ll see values written on it i.e;250v.3A in that case 3amps. Use a magnifier that makes it easier. the number before the"A" is the amp value.
Nov 16, 2009 | RCA RS2664 Shelf System
Blown amplifier
I would guess that during the move, the speaker wires crossed and smoked one of the output amp sections. The output transistors are shorted and are causing the fuse to blow. If you can post hte model number, I'll try to get you more specifics on the parts that will need to be replaced.
Dan
Apr 01, 2009 | Arcam Audio Players & Recorders
Blown fuse in my dvd/vcr player
normaly its on the board
and with a magnifing glass
look at the side of the fuse it should say somthing like this
GMC 250v @ 2.00 ??? this is an example not
the value
Mar 28, 2009 | RCA DRC8335
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Amplifier problem
You may have a blown channel. Check for fuses inside but I don't think that it will help. Repair if the channel is dead is not worth doing as the amps value is probably lower than repair cost.
Sep 02, 2007 | Audio Players & Recorders
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
1,273 people viewed this question
Top Carver Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
jeff5may32
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
