Heating unit and stats are ok on my awz7303 whirlpool tumble dryer yet there is no heat
    President:
  • 1,922 Answers
Make sure you first have 240 volts of incoming power,then check the units terminal power block in the lower rear where power cord enters,then check the heating element for burned off power connections,if you're sure all thermostats are good
Posted on Nov 19, 2009
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
    heatman101
    Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
    Tumble drier not heating up
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
    If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
    heatman101
    Sep 06, 2010 | Whirlpool AWZ7303 Electric Dryer
    How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
    how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
    Jan 19, 2010 | Whirlpool Dryers
    My awz7303 jus blows cold air and won't dry my clothes
    With the power disconnected you can check the resistance of the heating element. Remove the back of the dryer. Remove the connectors to the element and if the resistance measured is any greater than 25 Ohms on 220V-250Vac models and 12 Ohms on 110VAC Models then the element will need replacing. If the element is OK then check the thermal fuse(s) or thermistor on top of the housing which are there to present overheating. That’s really all there is to it if the motor is running and the timer is working OK.
    Nov 14, 2009 | Televison & Video
    Dryer not heating, still tumbling
    your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
    May 25, 2009 | Dryers
    Hi, My Whirlpool AWZ541 condensing tumble dryer is not heating..the other functions appear ok. The two thermostats on the heating element have been checked and are working. It was suggested that a third...
    I identified the part on an online spares company and rechecked behind the lower front cover. Only the rear side of the stat was exposed,but it matched the image. I removed the part and found it to be the same stat.
    May 16, 2009 | Whirlpool Dryers
    Not drying clothes
    If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
    Let me know if you have any other questions.
    Phil
    Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
    Not Heating
    Common faults -
    1 The heating elements can fail (meaning open circuit)
    2 There are cut-outs (T.O.C's) that might need resetting
    3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
    4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
    5 Faultyconnections and burned wires may also be the fault.
    Free tumble dryer repair videos
    We have a Free full video library on appliance repair video’s
    Oct 18, 2008 | Whirlpool GEW9250 Electric Dryer
    Televison & Video Logo
    51 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
