Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Water on the floor at the same time each day ..could it be related to de-frosting ??
  • 11,896 Answers
It very well could be the auto-defrost feature since it is activated at the same time. Do remove rear access panel and make sure there is water draining into the evaporator tray built on top of compressor. If the water is not draining, run a pipe cleaner inside to check for cloggs, and make sure water drain hole is big enough to drain the wire.
Posted on Nov 18, 2009
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
What to do the ice bridge is too thick
First De-Frost. The same process can be speeded up by opening the Fridge Doors, remove the electric plug from the socket(i.e. switching off power) and wait for all ice to melt, drain the residual water and Re-Start the Fridge.
Regular defrosting(say Once in 10 days) will ensure there is no ice built-up!
Apr 12, 2012 | Freezers
Water on the floor
I am assuming it is a Frost Free freezer and the defrost cycle is draining onto the floor. There should be a plastic tray under the fridge to catch this water so it can evaporate. Remove the front grill and make sure it is in place and not damaged.
Dec 28, 2009 | GE Refrigerators
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Every day we found floor water pond around the unit
I had the same problem -- it's answered by Peyton here: http://www.fixya.com/support/t1731426-leaking_hotpoint_21_7_cu_ft_csx22bc
Mar 06, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
Things in our freezer started to thaw. After about 3 day of cool down the freezer completely shut down. The following day the refrigerator stopped working. Any ideas? One other thing, water started...
Several things hereto look at.First is your de frost timer (if older than 6 years)you can advance it with a screw driver or some by hand.Turn it until your fan in freezer comes on.If it does ,,take temperature in freezer and if its close to 10 degrees than you replace the de-frost timer. Any more help im here to help. Please Rate This !
Sep 08, 2008 | Maytag Refrigerators
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
98 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
