Question about Optical Coating Model 108 VHS VCR
Tape stuck in Sanyo VCR ! - Optical Coating Model 108 VHS VCR
  • 579 Answers
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 11, 2008
4 Suggested Answers
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
  • 103 Answers
SOURCE: Tape is stuck in VCR NV-SD230A with errror code F04
judt open the player and pick the tape out
Posted on Apr 07, 2009
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
A video tape got stuck inside of the VCR then.
Well there is a tiny button on the back of the VCR you can bearly see it but its there.
So you will have to take a small flatend screw driver like for eye glasses and see if it can press that button to see if the tape will now eject out. If not it will have to be repaired then.
Aug 30, 2011 | Sanyo VWM-800 VHS VCR
My sanyo 670 vcr player tape does not play,rewind or forward. It does just create some ratting sound and stops.
This sound like you have a tape stuck in the VCR. you should goto a Video engineer to get it taken out. And then check it out to see what is going wrong.
hope this helps
Apr 13, 2011 | Sanyo Televison & Video
Won't turn on video tape stuck halfway inside
Stuck halfway inside could indicate that the actual tape is stuck in the capstan/heads. It may have never fully released from the mechanisms and returned to casing. Basically it ate your tape. You could try taking the cover off the unit and manually and carefully remove jammed tape. Unplug the unit first. Hope this is helpful.
Apr 29, 2010 | Sanyo DVW-7200 DVD/VCR
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Tape is stuck in sanyo vcr 4200
Take a phillips head screw driver,,take out the screws on the side and back of the vcr,, then pull the top off,, and reach in ther and pull the tape out,,, before you use the vhs player again ,,you might want to try a vhs headcleaner on it,,good luck,, thanks
Oct 05, 2008 | Sanyo Televison & Video
Sanyo vcr VHR-9433
Your end of tape sensor is not working. Notice the beginning and end of each tape is clear? That is to allow IR (infared light) which you cannot see with out special stuff, into the area near the left and right of the cassette. Usually they look like a tiny light bulb wit a left and right side. Radio SHack carrys IR detectors cheap.
Jim
Sep 27, 2008 | Sanyo VHR-9433 VHS VCR
Sanyo DVD/VCR Recorder/Player
How do i conected via sky+ to watch programs and record by telli
Mar 17, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
Tape is stuck
i think u broke some parts in the tape loading mechnism or u misaligned the initial position of the mechanism. thats why the error is still there. some switches still activated. i suggest that u bring it to a qualified technician if u dont know anything about this.
Jan 01, 2007 | Sanyo VWM-800 VHS VCR
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
Televison & Video Logo
385 people viewed this question
Top Optical Coating Televison & Video Experts
Marvin
Marvin
Are you an Optical Coating Televison and Video Expert? Answer questions, earn points and help others
