Question about Dell Dimension 4400 PC Desktop
Adding a PCI ethernet card?
I have an old but trusty Dell 4400 pc. I recently received a new hub from my broadband provider and would like to connect it to an ethernet connection on the pc. They advise me I needs PCI ethernet card which seems simple enough to put in. Can you tell me pleaseL
What do these cards do and what are their advantages?
Is there anything to be aware of in purchasing one?
Thanks,
Peter
    President:
  • 1,015 Answers
A PCI ethernet card is used to create a LAN port on the computer so you can connect it to a highspeed modem or router. The advantage of using a PCI ethernet cart as opposed to a USB is as follows. One is cost: PCI ethernet cards can be purchased for under $20 dollars(some USB adapters are $30 plus). And two is speed: USB 2.0 adapters are pretty fast but not as fast as PCI cards(your older Dell might not even have USB 2.0 and 1.1 is very slow). And three: A USB lan adapter will take a usable USB port away from you. As far as purchasing one you do not need to spend a ton of money. They are all pretty standard and the cheap ones work just as well as the expensive ones. Check out www.newegg.com where they have good prices and a large selection of computer components.
Posted on Nov 18, 2009
Testimonial: "Very comprehensive answer, that answered my questions perfectly and pointing me in the direction of where to go to next Big thank you to muebe"
    Brigadier General:
  • 10,406 Answers
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Testimonial: "Thanks for being very clear and helpful."
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
Network card disappeared overnite
Before adding any ethernet card, try to restore your system by using system restore option available with windows to a date on which your system was perfectly working. If the your system works fine after that, then it is quite likely to have your system infected by malicious software or anti virus. Scan your system for virus. If the ethernet is not working then add a new card after disabling the on-board network card in the CMOS setup.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
My internet access through my ethernet cable keeps crashing.I have a dell inspiron 570 and have changed the ethernet cable,power cable,home hub.I can connect ok via wi-fi to my laptop but my desktop does...
Either that or the ethernet chip on the motherboard is failing - you will need to disable this one from the BIOS and install a simple PCI LAN card in its place
Aug 26, 2011 | Dell Inspiron 570 Desktop PC (I5707163PBK)
Hi, since having a new BT home hub, my inspiron 6400 will not connect wirelessly unless I do a 'repair' with it. Sometimes it detects broadband but wont connect wirelessly. My son changed the channel...
Most people have to just work out the configuration by them selves BT do offer a lot of support (0800 022 33 22) Their equipement is pretty good and widely used.
By the way the most least used channels are 1,6,and 11 there might be a default but these are the most complete channels which do not overlap(RE;
cnannel 1]--2.412 Centre frequency(ghz)
channel 6]--2,437
channel 11]-2.462
Mar 14, 2011 | Dell Inspiron 6400 Notebook
Hi there I have a Dell Dimension 3100, and at the moment it is connected to the internet via a cable to my BT home hub. Someone has told me all I need to do is get a wireless card and slot it in and then...
The card mentioned is a PCI wireless ethernet card card.
Open your tower and look at the motherboard, you should find anywhere betwee 3 and 5 pci slots
(Longish connector slots usually coloured white all parallel with each other)
A PCI card will slot into one of these, with its face (with areal on it) pokes out the back. You may
have to remove a small long panel secured by 1 screw from the back of your tower.
Once inserted, your pc will probably find it as you boot up and will ask for a driver disk. Put the disk provided in your optical drive and off you go.
You will then have to set up the connection between the PCI card and your router.
A bit easier would be to buy a Wireless dongle which just slots into a USB port, saves taking your pc apart. The rest of the hoop jumping is more or less the same.
Please note, its probably best to go for one with WPA-PSK security, WEP is a bit old now. Best to check what your router can accommodate.
If you're still not sure just type "PCI wireless ethernet card" and "Wireless USB adaptor" into ebay, you'll get loads of pictures of what you're looking for. You don't have to be a member.
Nov 28, 2010 | Dell Dimension 3100 PC Desktop
Modem problem
make sure all connections are right USB or ETHERNET and youre internet service provider settings are correct or possibly disable your firewall until you get a connection
Jul 23, 2010 | Dell Televison & Video
DEll Inspiron 6400 will not recognize a wireless connection or ethernet cable connection. It did work before we moved but now the computer will not detect connectivity.
Before your move did you tell your provider? as if you moved and your broadband is not activated at new address thats the problem!
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Dell Dimension 4400 PC Desktop Logo
374 people viewed this question
Alun Cox
