Question about Dryers
How to hold throttle advance? - Dryers
  • 1 more comment
  • robertcalvil Nov 19, 2009
    I'm trying to figure out how to hold the throttle advance while I pull the starting rope. It won't stay, and there doesn't seem to get enough gas going to the engine to let it start. All of the rest of it is working fine.
    It is a MAC 3216 32CC.
  • Garry Clelland May 11, 2010
    make and model please
    President:
  • 2,220 Answers
Every saw I own (7, including 2 Macs) is different than the next. Consult the Operator's Manual under starting.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Posted on Nov 19, 2009
2006 yz85 lunging at half throttle with clutch pulled in.....At the starting gate my son can only hold half throttle without the bike lunging like it wants to take off.Thanks in advance
You need to adjust the clutch, you may have to much free play, this causes the clutch to stay slightly engaged even with the handle is pulled all the way back. Another issue is did you use the correct engine oil, to heavy a oil will cause clutch stack drag.
Jul 19, 2016 | Motorcycles
Working on a 1998 Polaris 300 4x4 two stroke. rebuilt carb/new jets. set everything to specs, oiler, electric throttle cable, choke cable. the only way I was able to achive the 1/8"- 1/4" inch freeplay in...
Hi Kyle:
If it will run at high rpm and as you slowly decrease throttle it suddenly dies, there is a possibility that the low speed jut in the carb is either plugged or needs adjusting. Also , check the timing. If too far advanced, idle will not be good.
Mar 22, 2015 | Motorcycles
Engine bucks and backfires through throttle body under acceleration
for an engine to backfire through the throttle body means that the inlet valve is still open when spark occurs . That means that the timing is too far advanced . IT may also mean that the tappet clearance is out if manual adjustment or the hydraulic followers are pumping up and holding the valves slightly open especially at revs.
Mar 03, 2014 | 1995 GMC Sierra
Cruise control on 1996 Chevy Silverado won't hold speed
Possibly a broken wire in the steering column. Wires goint through the steering column for the cruise are so fragile when the tilt is used alot causing the wires to brake. Part is $70.00 through advance auto. Cheapest I've found if you order online.
Feb 18, 2013 | 1996 Chevrolet Silverado 2500
Troy-Bilt tiller with Tecumseh engine need help fixing carburator
i doubt it to be sure replace vthe rubber bushing that is what the problem is i think.
Aug 15, 2017 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Basically I'm losing a lot of corner speed, when turning into corners. I shut the throttle off too early and it feels like I'm carrying the bike round the corner. If adjust the throttle mid bend,...
You need to accelerate very gently while you go round the corner. This sounds wrong but even if you hold the throttle in the same position, physics dictates that as you go round the corner you do actually accelerate as you go round a corner at a constant speed (velocity/direction/speed - look it up if your interested!).
So on the approach to any corner, you need to: -
1 Position yourself and the bike for the approaching bend, toward the right hand side of your lane for left hand bends and vice versa.
2 Adjust your speed to one you can quite happily ride around your bend (Slow down by easing off the throttle or appling the brakes)
3 Once at the right speed, (off the brakes) select the right gear for the speed your doing.
4 GENTLY apply some throttle to stop the bike slowing down anymore.
5 Tip the bike into the corner by gently pushing on the left bar for left handers or vice versa keeping the throttle still so that you hold your speed through the corner.
6 As the bend opens up (becomes a straight) gently apply more throttle as you release the pressure on the bar and stop turning.
If you want to keep improving your riding skills, sign up to a advanced riding course. They are for people who enjoy riding and want to be safer and consequently faster.
Good luck with your riding and enjoy!
Jul 28, 2011 | Suzuki GSX 1300 R Hayabusa Motorcycles
95 taurus idling too high like it is stuck wide open
Several issues can cause this problem, either singularly or in combination.. Check the throttle body for dirt and sticky carbon deposits. clean the throttle body using a spray can carburettor/choke cleaner, and with the throttle valve held open, wipe out the bore of the throttle body with a solvent soaked clean rag. Make sure the throttle valve is not sticking any where in the throttle travel between closed and open.
Next, check the idle air bypass valve that is mounted on the top of the throttle body, for dirt and carbon deposits inside that can cause the idle air bypass valve to stick in an open position. Clean the inside of the idle air bypass valve with carb cleaner.
If the ignition timing is over advanced, (Specifies timing advanced is10 degrees Before Top Dead Center, with the in-line spark out plug removed from the spout connector housing, and with the idle speed set to the idle RPM shown on the emissions sticker under the hood, with the engine fully warmed up,) use a timing light to check and set the ignition timing to specification.
The throttle position sensor must be installed on the throttle body using the required method or the idle speed will likely be excessively high. Beginning with the battery negative cable disconnected from the battery, and with the throttle position sensor removed, place the sensor in position on the throttle body with the drive tabs on the sensor placed after the drive tabs on the throttle shaft, the holding the sensor on the throttle body, rotate the sensor counter clockwise to align the mounting screw holes in the sensor and the throttle body, Insert the sensor screws into the senor screw holes, into the threaded holes in the throttle body and tighten finger tight. Carefully center the sensor on the sensor screws, then tighten the screws firmly without over tightening. Reconnect the sensor electrical harness connector.
Inspect the throttle valve idle stop screw adjustment that holds the throttle valve open slightly, to prevent the throttle valve from touching the throttle body bore surface with the throttle closed, and the accelerator pedal unpressed.
Dec 30, 2010 | 1995 Ford Taurus
How do I advance my engine ilde speed it seems to slow when at a red light its about to cut off .
i would suggest cleaning the throttle body before adjusting anything, disconnect the air cleaner assembly from the engine and have somebody hold the gas pedal to the floor with the engine off and use some carb cleaner and spray it on a rag and clean all the black stuff out of the throttle body that is just beyond the throttle plate that opened when your helper pushed down the gas pedal,that should cure your low idle problem,hope this helps
Oct 12, 2010 | 2002 Ford Ranger Regular Cab
88 thunderbird running high rpm
Idle air control valve,Its mounted on the throttle body looks like a round tube.Its very simple to replace just remove the two bolts that hold it in place.You can purchase one at your local advance auto parts.
Feb 03, 2010 | 1988 Ford Thunderbird
My throttle control ,it like i have to turn it to the right at maximum distance and then hold it, sometime it goes fast but sometimes it stays at a lower speed and thenbumps up to a faster speed...
It sounds like it is binding. With the motor off disconnect the throttle cable from the motor. Then grab the throttle lever on the engine and work it manually by hand. There are a couple of wires under the cover which move to advance the spark. They can jam when they move and you will get a delayed advance when they work free. If no problem manually, then your long throttle controls are binding before the engine. Also note the angle of the engine and if the throttle controls are rubbing the transom.
Jun 11, 2009 | Boating
Dryers Logo
137 people viewed this question
Top Dryers Experts
