Question about Toys
I just received front upper and lower arms for my mad warrior truggy. Are they suppose to have threads cut into them or are you suppose to just jam the bolts in?
    Scholar:
  • 152 Answers
The arms themselves should not have any threads cut into them, they should be free to pivot on the hinge pins at both ends. The hinge pins should be attached by e-clips on either end.
If you feel this solution has assisted you, please rate it! Thanks, and good luck!!
Posted on Nov 19, 2009
Latitude. How can I replace control arm and ball joint assembly?
Lower you can do fairly easy. Upper, a bit tougher.For the upper you will need a spring compressor.
Mar 21, 2016 | 2011 Jeep Patriot
Timing if upper and lower loopers
if you look closely at the components of the machine they should have small marks on them that line up with each other or marks on the case. most sewing machines are timed this way the marks have to be lined up on both arms and that should work.
Jan 14, 2008 | Simplicity Frontier SL390 Mechanical...
Why does upper thread break when I try to sew zig zag stitch?
Your tension sounds too tight, try lowering it on the upper thread. Or you may be using a cheap thread which frays easily and frays in the needle. Try using a longer zigzag to see if that works. Is straight stitch smooth?
Nov 02, 2015 | Brother Ls-2125i 10-stitch Portable Free...
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
Mylock 334d
Your thread tension wheel may be set to too high of a tension, which will cause the thread to pull out from the bobbin. Try a lower tension setting.
If set too low, then threat from the top end would hang loose and possibly snag, instead.
Oct 14, 2013 | Sewing Machines
What does the control arm on the front left driver side supposed to look like fully assembled
Hello! First diagram is the lower...Second is the upper..Guru...saailer
LOWER IDENTIFICATION:
Item
Part Number Description 1
5495 Stabilizer Bar Link Bolt and Bushing Assembly 2
18A192 Nut, Washer and Bushing Assembly 3
808264 Bolt 4
5005 Frame 5
5B326 Torsion Bar (LH) 6
5B327 Torsion Bar (RH) 7
620481 Nut 8
5C491 Nut and Washer 9
3079 Front Suspension Lower Arm (LH) 10
3078 Front Suspension Lower Arm (RH) 11
3A130 Tie Rod End 12
808166 Nut 13
808167 Nut 14
5K483 Front Stabilizer Bar Link 15
5482 Front Stabilizer Bar 16
5484 Front Stabilizer Bar Bushing 17
3B353 Front Stabilizer Retainer 18
N807396-S100 Bolt A
- Tighten to 40-55 Nm
(30-40 Lb-Ft) B
- Tighten to 150-200 Nm (111-148 Lb-Ft) C
- Tighten to 21-29 Nm
(15-21 Lb-Ft)
UPPER IDENTIFICATION:
Item Part Number Description 1 3C156 Damper Assembly (RH) 2 805348 Nut and Washer 3 - Shock Absorber Insulator
(Part of 18198) 4 3C157 Damper Assembly (LH) 5 3020 Front Suspension Bumper 6 3083 Front Suspension Upper Arm Assembly A - Tighten to 34-47 Nm
(25-35 Lb-Ft)
LOWER DIAGRAM FOLLOWED BY UPPER:
Feb 12, 2012 | 1996 Ford Explorer
Dishes do not come clean
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Maytag Dishwasher
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Just replaced my uppper looper on my white 1634....
Hi.
The upper looper goes just in front of the needles. I had issues with my machine when I got some fabric jammed and the looper moved so it wasn't catching the left needle and it was sewing a straight stitch on the left. The looper needs to be placed in front of the needles and very close to the needles without hitting them.
Hope this helps!
Cherie
Nov 01, 2008 | Singer White Speedylock 1634
Toys Logo
18 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
