Question about MSI KT6V-LSR Motherboard
User's manual Please advice where to find mother board's user's manual. I need to change hard drive to SATA drive. want to know what jumpers are required to be changed. thank you zouz626@hotmail.com
  • zouz Jan 12, 2008
    thank you very much for your help but the thing is it didn't work. I did reset cmos and everything else I could think of. any more hints or tricks.
  • zouz Jan 12, 2008
    ok, the original hard drive W/D EIDE quit working and since motherboard accepts SATA drives I decided to replace it with one. I hooked it up wired it like it supposed to but when I turn the PC on and go into the bios to see that it detects the new drive it doesn't detect it. the new hard drive came with a cd and I follow the steps until it asks me to select the proper drive icon but it won't because it faded due to undetection of drive. The cables only attach one way and I am very careful with such things. my last resort is to return the drive to the vendor and get a new one. but I don't think it is a bad drive because even if it was it would say bad disk........etc. this one doesn't even get detected.
    the motherboard is KT6V-LSR (601-7021-020)
    THANK YOU
  • 589 Answers
You shouldn't have to change any jumpers. The only jumper I see is to reset the bios.
Posted on Jan 10, 2008
  • brian c
    brian c Jan 12, 2008
    Can you tell me exactly what you're trying to do?
    Are you doing a fresh install, etc?
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Hard drive configuration
look for a sata connector on your main board that looks like this:
http://images.tomshardware.com/2005/11/23/pc_interfaces_101/sata.jpg
If your main board does not have one of these connector then you do not support SATA. If it does make sure you connect the drive in SATA0 or SATA1 what ever is the lowest. Also SATA does not require any jumper configuration.
Jan 15, 2009 | Intel Motherboard
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
Unable to use SATA hard disk with existing IDE Hard disk
Hi abhinav13, please disconnect you're IDE. (do not remove it).
You're board only supports SATA 1.0 which is 1.5BG & not the SATA II at 3.0GB. Knowing that you may need to use the jumper to set the drive to 1.5GB. Once you are sure the drive is set correctly than hook it into the PC. If after disconnecting the IDE & SATA drive is shown in the bios. Set the jumper on you're IDE to function as a slave drive.
Enter the bios again. If you do not find the SATA drive listed than your onboard SATA controller is defective. You can not fix that.
So hate giving out bad news.
Luck!
Mike
Apr 09, 2008 | MSI K8MM-V Motherboard
Hard driver (seagate)
hi,
is it a sata or ide (pata) drive? does the bios recognise it yet? if it does then you know you have a software problem which could mean you may just need to partition or format the drive.
if the bios can't even see it then you will need to change the jumper settings on the harddrive to make it compatible with your mother board.
good luck
smeags
Jan 07, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
MSI KT6V-LSR Motherboard Logo
467 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
