Question about Ovens
Ice continually forming on bottom of upright freezer
Several times a year I clear ice from the drain at the bottom of my freezer (whenever I notice a sheet of ice on the bottom). Is there a reason why it keeps happening? Something I can fix once and for all? I don't notice anything clogging the coil. Is it safe to wrap a copper wire around the heating element and insert it into the top of the drain to prevent the ice from forming?
  • pm2conley Nov 19, 2009
    I meant I didn't notice anything clogging the drain/hose, not the coil. I always pour a bunch of water down the drain after I clear the ice to make sure it's coming out the other end quickly so I don't think there's anything blocking the hose. Why would this problem be happening again and again?
    Sergeant:
    Champion:
  • 289 Answers
You nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Posted on Nov 19, 2009
How do i clean with a melted black plastic meat container all over bottom of oven
Defrost your fridge freezer, put all the ice and snow etc on the container wait 30/60 minutes, get a hammer and chisel, be carfull...
Apr 20, 2016 | Ovens
I have a Frigidaire Gallery Refrigerator with bottom freezer that is only 3 yrs old. My problems are with the ice maker and the door seals. The ice maker in the top in the refrigerator makes ice but f
Thank you for your post, Genie Byrd!
From my understanding your Frigidaire refrigerator is not sealing properly which is causing an issue with your icemaker. You may need to replace the component for your seal. I would recommend having a professional technician out to your home to properly diagnosis and repair your refrigerator. Are you under warranty? Typically, if you are under warranty a repair should not come out of your pocket. I would consult with your manufacturer for warranty coverage. Hope this information helps. -OOS
Nov 22, 2014 | Frigidaire 27 in. Electric Gallery Pro...
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
I have water pooling in the bottom of my fridge, what would it be
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
Apr 27, 2012 | Ovens
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Water works but icemaker does not. the freezer barely cools
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 11, 2009 | Ovens
Ice cubs ar melting GE double door frig what can be the problem?
If the ice cubes are the only thing melting it could be the heater in the ice maker which thaws the ice a little to release it from the mold.
If other things start melting it could be auto deforst failure indicated by iceing of the evaporator coils behind the rear cover in the freezer.
Aug 29, 2009 | Ovens
Maytag Model MTB2154ARW-water is appearing inside on the bottom of the refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Maytag CWE5800A Electric Double Oven
Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
98 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
