Question about Ovens
Oven switch does not start oven unit, switch does not light up.
  • 11,896 Answers
Either the switch is bad or the pilot if gas, or relay or circuit if electric. You can test the swtich with an ohmmeter to see if there is power to and from the switch. Use the ohm setting and place one probe on each wire to get a reading. You can get parts and manual at repairclinic.com or partselect.com
Do test before replacing.
Posted on Nov 18, 2009
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
It,s always written DOOR on my lcd oven board.The oven doesn't heat.
Hi, it sounds like one of the "lock" switches for the self clean door lock assembly may be faulty, or the oven door light/monitor switch is faulty. Is the oven light "on" ? Either that or when the unit was last placed in self clean the cycle may have been interupted by a power failure or some other accidental/intentional "cancel" command. Try unplugging the unit and plugging it in again right away. The "reset" should force the oven thru a start-up cycle, it essentially makes the onboard "watchdog/monitor" in the processor to check all the switches for the proper position and makes the lock go thru a lock to unlock position. The unit may correct itself just by going thru this off-on process. Hope that helps, let me know. Good luck
Oct 01, 2009 | Ovens
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
Jun 04, 2008 | GE JKP20 Electric Single Oven
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
