Question about Dell Inspiron 6000 Notebook
DST Error Motherboard or HD problem
I was wondering if I get a DST Failure on the diagnostic is it the HD itself or the motherboard is the problem. How can I test for it?
  • 89 Answers
What is the manufacturer of the PC?
Posted on Jan 10, 2008
Error message 2000-0151 on dell inspirion 1545
Hi.
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Hi, I have a dell d505 laptop and am getting a dst short test error when running the diagnostic. someone told me I should run the recovery cd, but I no longer have it. How can I get one ? Is there a way to...
You can download Dell Diagnostics from Support.dell.com for your model system, and see if you get a failure indication there. If you get a failure during Dell Diags, then it should help you ID the failed component. If the Diags pass, it is only indication it didn't FIND a failure, so there still MAY be a hardware issue. (Diagnostics only look for a limited selection of possible errors, so failures may still exist, even though a component passed a diagnostic.)
If you are having a memory issue and have two ram modules, best test is to try each module in the system by itself and see if issues go away, if they do, then the one module that generates errors is likely bad.
Jun 28, 2009 | Dell Latitude D505 Notebook
It wont power on.With a diagnostic fail of 1000-0146
DST stands for Drive Self Test, bunnydawg is correct in the drive is failing
Mar 08, 2009 | Dell Latitude D600 Notebook
DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Feb 05, 2009 | Dell Latitude D610 Notebook PC
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Dell Inspiron 6000
The short DST test is generally the failure of the HDD,It would giive you code next to it , that would something like 1000-0146,or 1000-0141 etc. Do give that code and I would let you know the exact failure
Thanks
mandeep
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Motherboard or Hard Drive problem
Testing mother board:
1. remove memory:
if the mainboard produce long beep means good.
if not that is bad.
2. if produce long beeps then insert the memory.
3. if same happen.hear long beep. then clean or replace memory.
If your are sure evething is ok in the mboard; then you can test your drive:
Hard drive test:
1. first fixed well all the connection bet the HDD.
2. if work then ok, if not then,
3. replace other IDE cable/ sata cable and fixed well again.
4.if still thesame; then
5. examine your HDD , the circuit maybe shorted.
Jan 11, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
71 people viewed this question
Alun Cox
