Question about Panasonic DMR-ES10 DVD Recorder
DMR-ES35V Cannot operate any functions ...
unit is set at in1... remote will not operate any functions the only change it allows ... it will change the IN I to SET I ... what does this mean While attempting to find format on the display page I did hit "reset default" and that's when nothing was abled. didn't wt
  • 5 more comments
  • jace5063 Feb 09, 2008
    my dvd recorder just says SET 1 and the remote does not function
  • Anonymous Feb 17, 2008
    I have same problem. All of a sudden the unit's display says Set 1, and there is no visual on my tv to be able to follow the directions in the manual. When I click on Functions on the remote, nothing comes up on the tv.
    My case is similar. I have a DVD loaded, I get the title screen. When I hit any button on the Remote, the LCD display on the unit just flips to 'Set 1' and nothing on the remote works. I can hit the play button on the unit and it does play.
  • Chapski Mar 08, 2008
    Same problem as described by other posters. No solution?
  • Anonymous Apr 16, 2008
    recorder says set 1 when operating the remote control
  • sassie62 May 16, 2008
    the solution holding the 1 and enter buttons fixed the problem with my remote!! TY very much!!!
  • lh0722 Jul 23, 2008
    Set 1...I have the same problem. Clicking remote produces only `Set 1' on the unit which will not respond. Suggestions?
Just found the answer in another post, it works.
Hold down the "1" button and the "Enter" button together for about 10 seconds while pointing at the player. This seems to "reset" the remote and everything works fine.
Posted on Mar 08, 2008
I can confirm holding 1 and enter for 10 seconds works, just tried it and it did. Thanks! SEL 1 Problem solved! Yah!
Posted on Feb 02, 2009
More than (3) years later and this is the fix! This is the first time we've experienced the "SET 1" problem with this unit, in the 4-5 years we've had it. Did a quick Google search, came up with this site and PRESTO...problem resolved. Thank you to those who posted both the problem and especially the Solution!
And yes...still using a VCR. ;)
Posted on Oct 25, 2012
  • 3 Answers
Just tried the above solution... Presto-change-o....it works, thanks!!
Posted on Apr 23, 2015
My dmr-es35v can't read any kind of dvd. what can be wrong?
Laser pickup unit fault. Check and replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 18, 2017 | Panasonic DMR-ES35V Multisystem Code free...
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
DMR-ES35VS: How do I connect my Panasonic DMR-ES35V through a ...
Put the main aerial into the set top box,then take a male to female fly lead and connect it to your panasonic,then take another fly lead from the panasonic into the tv.If you have two scart sockets on each unit and the tv you can connect one into the tv from the box and one from the panasonic into the tv,then you can connect the box to the panasonic so you could record from the box.
May 05, 2010 | Panasonic DMR-ES35VS
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Oct 11, 2008 | Panasonic DMR-ES35VS
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Need help
I have the same model, i pressed Function key(on remote), enter, using up and down arrow keys, select Setup, Remote control code, press 1,2 or 3, then enter. The code on the unit has been set. You must use the same code for the remote control by pressing enter and hold for about 2 seconds at the same time pressing corresponding 1,2 or 3 you selected for unit. This makes the unit and remote compatible with each other. you only change this code if you have other panasonic products that respond to this same remote control. hope that helps.
Jun 14, 2008 | Televison & Video
Panasonic DMR-ES10 DVD Recorder Logo
1,090 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
