Question about JVC AV-32750 32" TV
I order parts kit tpcd-0002 however i do know where to install the parts. I understand there should be a bulletin sb-9607-a but i cannot find it any help will be appreciated. Thanks
  • 1 more comment
  • chris leck Nov 19, 2009
    The tv is a jvc av-32750 and the problem is a popping noise from the speakers. Are the parts in the kit replacing parts are the additional components /
    Thanks
    There are not any missing components the kit has three parts and the bulletin should explain where they go from what i undrestand
    I have received a copy of the bulletin from jvc after arguing with them.
    Thanks for your help
  • JVC Master
  • 5,807 Answers
what i need to know is do you want me to explain about " tpcd-0002 "
and the same with a "bulletin sb- 9607" or just wanted to have your
TV problem resolved.
if the answer is the resolving your TV problem please indicate the
make and model , might as well the chassis number of
your main board.
or state at least the part number of your main regulator and the
horizontal output of your horizontal deflection board.
state the actions you have done on the TV , state the B+ voltage
of the main regulator ( the line that goes to the Horizontal Output
Transistor) , might as well describe the real problem your TV is
having.
Schematics and bulletins are just guidelines to help facilitate a
speedy repair but the real components depends upon the
components installed on your TV, some are applicable some are not
they are just an aid, the real solution to the problem is actual
troubleshooting , actual replacement of components and actual
voltage measurement on the circuit board. not unless the voltage
measured does not matched to the voltages stated on the service
manual then obviously there is a problem with that area.
Posted on Nov 19, 2009
  • Rommel Cana
    Rommel Cana Nov 19, 2009
    these could be one of the possible location of your components
    but on my own opinion , or suggestion include the 4.5 MHz filter next to it.
  • Rommel Cana
    might as well post the other missing components
How long does sb stays on my Frigidaire refrigerator
Hey friend, thank you for your inquiry!
I understand that you would like to know how long "sb" stays on your Frigidaire refrigerator. Typically the "sb" stands for Sabbath mode and will turn off only when it is turned off at the control. I hope that is helpful. -Matt
Sep 19, 2014 | Frigidaire Refrigerators
Multi-information display went out. Cannot locate broken fuse
There is a service bulletin that advice the replacement of the comvination meter ecu (convination meter bulletin number t-sb-0172-09.
there is another bulletin for a warranty extension, visit your friendy toyota dealer for more info.
Jan 04, 2011 | 2006 Toyota Prius
My microwave seems to have overheated and is not shut off. breaker is okay, outlet works
Well Certain models of Whirlpool microwave ovens have a problem with their thermal fuse that causes them to overheat. Whirlpool has a service bulletin out on this problem.
CORRECTION: Install a thermal cut-off repair kit (Part #8205204) to
repair the wire and terminals. Once this is done, a new
rework kit (Part #8184461) must be installed.
Good Luck!!
Thanks
Dec 28, 2009 | Whirlpool GH7155XHS Microwave Oven
I have a 2001 chevrolet blazer and need to get the airpump replaced in it i have heard that i also need to get the breather vent extention kit. But i do not know where the best placetoget these two items...
Hello jesspurvis: My name is Roger and I will help you. Their is a GM tech bulletin for this . The bulletin number is 04-06-04-015A. The bulletin gives part numbers for the extension kit you will need. The only place you can find the parts is from a GM dealer. I know of no aftermarket for the parts, Also to replace the air pump and extension kit. A lot of it is done from under the vehicle. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
Oct 29, 2009 | 2001 Chevrolet Blazer
2009 Camry Downshifting Problem
this is normal operation for this car... i have the same type of car with same issue..
Jul 28, 2009 | 2008 Toyota Camry
Can anyone tell me what parts in jvc INSTALL KIT # TPCD-0002 ?
The repair kit consists of:
QCS31HJ-470AZ (47 ceramic disk cap.)
QCY31HK-222AZ (222 ceramic disk cap.)
CEKO026-1R0Z (peaking coil)
I know it has to do with audio buzzing in some JVC TV's but can't seem to locate the bulletin on it. Please take a few moments to rate my answer. Thanks
Nov 19, 2009 | JVC Televison & Video
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
HAIER 42 PLASMA
Installation of the upgade kit is fairly simple. Just watch the pins which connect to the boards when plugging and unplugging. Sears offers the kits at 178.00. or they did. I'll attach upgrade instructions with the kit number. http://service.haieramerica.com/documents/SB-TV-0003.pdf
Jul 16, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
bbmw@bellsouth.net
Aug 17, 2006 | Nikon Speedlight SB-800 TTL Flash
Open Questions:
See all JVC AV-32750 32" TV Questions
Televison & Video Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
