Question about ASUS P4S8X-X Motherboard
Opened computer panel and then when i rebooted nothing happened.
Something was in my flash card slot so i opened it up and took it out. then when i rebooted it does nothing but diplay r-red , b-blue, g-green on a black moniter screen . please help
Did you disconnect the power before you stick something in there? Because the FDS Has power to it when the PC is turned off... You probably shorted out the mother board....
Posted on Nov 19, 2009
Motherboard beeps 2 long beeps upon start up ?
More then likely it's your memory or video card.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Gigabyte GA-990XA-UD3 ATX AMD Motherboard
Hello, I have an Acer 8920G laptop which uses the Jmicron JMB38X SD controller. My current operating system is Windows 7 and my problem is that even after a clean install of the Jmicron drivers my...
Windows 7 is the ONLY problem. I see this time & time again. Usually you do NOT need a driver for an SD card usually they simply "Show up" as a "Drive" in My Computer. They get "Detected" and and Windows will install a "Generic" driver. If they don't 8/10 they are faulty. See if you can get it to work an someone else's XP machine.. That will at least prove the card.see it with your own eyes.
Feb 03, 2010 | Computers & Internet
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
Acer Aspire 6920 6-in-1 card reader
put ur SD card in and restart will install all drivers and will make the card reader work
Mar 19, 2009 | Acer Aspire 6920 Notebook PC
I have a dell desktop htat i took the ram out of to try some free ram a friend gave to me. when i seen the ram wouldnt fit i reinstalled my ram i took out. i now get beeps and the monitor wont come on....
are there 2 slots for ram do you have 1 mem card or 2
if you have one you have to make sure its in the right slot and seated properly.
if one check that its seated properly ....reboot
if nothing remove and reseat in other slot..reboot
Jan 06, 2009 | Computers & Internet
Fujitsu T4220 Flash Memory Drive
hmmmm.....
First of all try unmapping any other Drive that is connected.
lets say u have external harddrive and it had drive letter F:
When u put the SD it for some reason wants that Drive Letter and when it is occupied with some other device it will not show up.
Also u want to check the Bios settings if that card reader is enabled.
If u can open up the cabinet( Tower ) thrn check if the internal connection to Mother board are alrite.
Feb 10, 2008 | Electronics - Others
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
TV signal lost
Have you had a look at the cords? Is there any damage to the hardware itself? Maybe there is something else wrong. Tried running virus scans? I know it's a long shot but it's amazing at what viruses do to your machine.
Mar 24, 2007 | ASUS V9520 Magic/T NVIDIA GeForce FX5200,...
Video card is giving me problems
Make sure the videocard is set in the slot. You should remove and reseat the videocard. Then go to: http://www.nvidia.com/content/drivers/drivers.asp and download the latest video drivers from here and try installing them again. Old video driver can kill!!! Let me know what happens. Good Luck. Tim
Mar 15, 2007 | XFX GeForce4 Mx440 (64 MB) Graphic Card
ASUS P4S8X-X Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
