Question about Kitchen Ranges
Only one burner works. oven works. What is wrong with the other burners, we have a train 3 blocks away is it the vibration?
  • 10,865 Answers
Hello. Generally when burners do not work the culprit is one of two things: Grease and other debris in the burner which can be cleaned with cotton swabs and degreaser, or loose wire connections. Just wiggle each wire connection and if it comes off it is too loose, tighten it up with a pair of pliers.
Posted on Nov 18, 2009
Oven does not ignite. Replaced igniter. Will light with match
It could be the igniter is too far away from the burner or the little holes that shoot the gas to the igniter are blocked with soot. I have seen where something has been pushed too far back and bent the igniter frame away from the burner too far to ignite.
Sep 30, 2015 | Kitchen Ranges
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
Burner 1 and burner 2 from right to left work very well, burner 3 acts as if the regulator is malfunctioning. Comes on very low, blow back thru the regulator tube. Multiple trys of turning off gas,...
try cleaning burner 3 could be blocked , or it could be split , the air mix could be wrong you can move the air mix slider to give more or less air , see if the orffice is blocked . or you could try changing the reg but don't see that being the fault.
Sep 04, 2011 | Camp Chef Big Gass III - SPG-90B Grill
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
The oven will not ignite.. the burners and boiler will
Most of the time it is a weak ignitor. I have a training video HERE
Jan 28, 2010 | Kitchen Ranges
Gas oven is working fine but none of the burners are igniting
The little gas ports maybe blocked on the burners, try cleaning the ports, also on the burners there are 3 or 4 small pin holes for the gas to travel, a small paper clip will remove any debris trapped inside these holes once they are clean the burners should light
Oct 30, 2009 | Ovens
I have a Frigidaire stove, when I turn the oven on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Have you spilt anything on the burner? If so it will need to be cleaned,you will need to do the following (you need a pin, a matchstick, a drinking straw and a torch):
Make sure the oven control and the electric isolated is off please, remove the shelves, using the torch, inspect the oven burner, if there is no apparent blockage, disregard the following advice and seek the help of a 'Gas Safe' engineer in your area.
If it is blocked,using a pin or matchstick clean the holes in the burner, and use the drinking straw to blow the debris away. Move away from the burner, and see if it lights.
If this fails to work it could mean that the ignition is in the incorret position allowing for explosive ignition. See advice from a 'Gas Safe' qualified engineer.
I hope this helps.
Jul 06, 2009 | Frigidaire FGB24T3A Gas Single Oven
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
