Question about Delfield (F18WC60) Commercial Refrigerator
Delfield commercial refrigerator leaks from fan area above top shelf
  • Delfield Master
  • 1,253 Answers
Check for clogged condensate drain.
Posted on Jun 07, 2010
Evaporator freezing up on delfield prep table
unit should have a defrost cycle.If defrost does not engage due to you unplugging it.the fan inside could freeze up.it will continue to freeze until alll ice is removed from fan area.Also check drain.
May 07, 2012 | Delfield 4464N-12 Commercial Refrigerator
Where can i get fan motor for delfield 407a in des moines, ia. its the cooling fan in back not the one inside.
Hello Jfarrell677,
Here is your local service provider for Delfield in your area they should have the part or be able to order it for you.
Goodwin Tucker Service Co
2900 Delaware Avenue
Des Moines
Iowa
50317
USA
Email : dgoodwin@goodwintucker.com
Telephone : (515) 262-9308
Thank you for choosing FixYa.com
Justinbur167
May 11, 2011 | Delfield Undercounter Freezer - 407CA
Delfield vs bev air, which way would you go for a used 2 door under the counter refrigerator in a concession trailer?
I'm not a big fan of either. I've been involved in the restaurant business my entire adult life and neither one impresses me. If I had to choose, it would be the Delfield but keep in mind that their parts have to come from a Delfield supplier. Bev-Air parts are a little easier to get except for things like door hinges and door gaskets. Sorry that I can't really be much more help than this but this is my opinion based on experiences.
Feb 07, 2011 | Delfield 64'' Refrigerated Sandwich Table...
The delfield box 18672ptb has no tags andi need to know critical charge
my chart says 32 ounces of R-404 A. Remember, cap tube systems are charged by super heat and TXV systems are charged by subcooling or full sight glass if system has receiver.
Feb 01, 2011 | Delfield 18672PTB Commercial Refrigerator
Delfield ColdPro Refrigerator, Commercial unit, two door reach in... recently has begun to freeze.... Temp setting stays at 37F and for some reason, just on occasion it will drop to 0... and everything...
Intermittent failure of thermostat is the most likely problem.
Check the temp sensor to make sure it is clean.
You can check for voltage coming out of the thermostat when the unit is working improperly.
If the setting is on.... say, 36, the temp is... say, 26, and there is still voltage coming from the T-stat telling the compressor and fan motors to operate, then you have a bad T-stat/sensor.
Most T-stats for that type unit do not have a separate removable sensor, its all one part with a sensor on a long tube/wire.
You can probably buy one from your local refrigeration supply warehouse for less than 35 bucks.
If it were a more consistent problem, I would say you have clogged coils or low refrigerant. But if most times it works fine, and then just randomly will not shut off, that's likely a controls thing. = T-stat.
Jan 02, 2010 | Delfield (F18WC60) Commercial Refrigerator
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Delfield model #mrr2n-s ser. 0403036101321-t ice
can not immediately locate manual.
If this unit is a cooler, check this:
Anything that can effect air flow. Fans not running or running in wrong direction.
Too much product in unit.
Thermostat set too low or stickes and unit does not shut off unit.
Possibly has a defrost timer. Most coolers do not but some do. Look for one and see if it is working. Make a mark on the face and wait 15 minutes to see if it moves.
Drain pan clogged.
Doors not closing or seals not sealing.
these are the things to check out.
Aug 03, 2009 | Delfield (F18WC60) Commercial Refrigerator
Delfield 4048-12 freezing up!`
Yes, it could be the thermostat. Here are all of the reasons that could be causing your problem Read through them as a guide on how to proceed. Get back if I can help you further.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
May 21, 2009 | Delfield 4464N-12 Commercial Refrigerator
Delfield model st4660n 2door cooler no cold air
sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Dec 09, 2008 | Delfield 60 Refrigerated Work Top Model...
Delfield (F18WC60) Commercial Refrigerator Logo
138 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
