Question about Whirlpool Duet GHW9150P Front Load Washer
Our temperature control isn't working. If we put
Our temperature control isn't working. If we put the washer on cold/cold, we find the hot water tap still turns on. When we turn off the hot water tap, the washer starts, but stops after about 10 minutes, flashes 'H' and 'F'.
  • 126 Answers
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Posted on Nov 19, 2009
Hot water does not come in, only cold water comes in, the water pump works on cold water does not start on hot water
There are no water inlet pumps on standard washers- the water, both for hot and cold, is fed in simply under 'mains' pressure.
(The following is pre-typed for hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef CAV2000AWW Top Load Washer
Washer don't get the cold water only the hot cold water won't enter and the hot enter extremelly hot
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
John C
Aug 27, 2011 | Frigidaire FWS833A Top Load Washer
The model of my LG WASHING machine is WP 750((N,R)(P) AND IT IS A TOP LOADER,THE SPIN BASKET WORKS BUT THE WASHER ISNT WORKING.
Sorry but your description of 'isn't working' has very little detail in it so I am trying 'poor water fill' first:-
John C
Aug 14, 2011 | LG WFT1071TP Top Load Washer
When the facets are properly attached to the rear water inlets the hot works but not the cold?
(this pre-typed covers both hot and cold!)
John C
Aug 13, 2011 | Frigidaire CWS3600AS Top Load Washer
I have a frigidare washer and after a few minutes the cold water stops coming in too the washer but the hot water still works we have undid the cold water hose it is a constant stream it does not stop...
(check all of these things but for 'cold' only!)
John C
Jul 24, 2011 | Washing Machines
Cold water connected but only the hot water works. rinse cycle not working at all.
(check these things but for 'cold' only!)
Rinse uses cold only so it will not work without the cold water.
John C
Jul 24, 2011 | Admiral AW22 Top Load Washer
I can't get cold water anytime selection from water temperature requires cold only or combination cold/hot. I only get hot water. Can you help me solve?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
John C
Jul 14, 2011 | Hotpoint Washing Machines
Hi my machine wont switch on can hear clicking. But when I put it on to spin cycle to drain and water seemed to drainii
From your description it sounds like there is no water entering into the washer
John C
Jul 14, 2011 | Candy CNW136 Front Load Washer/Dryer
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Do we need a Y connector for our combo washer dryer. We just have one tap in the kitchen sink
If you use a Y connector to provide water to the washer it will not be able to use different water temperatures. The water temperature at both the cold and hot inputs will be whatever comes out of the tap. The washer controls cold and hot inputs separately to change teh water temperature in the machine. A Y tap will only provide one temperature (whatever the tap is set to provide) to both inputs. If the tap is a faucet you could control the temperatures manually but the machine needs to have a water supply at both of its inputs.
Dec 08, 2009 | LG WM3431H Washer and Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
