Question about Teac PD-D2610 5-Disc CD Changer / Player
After 16 months our PD-D2610 CD changer has started misbehaving. Some of the 5 positions work fine but positions 1 & 4 almost never work.
I read enough comments from unhappy TEAC owners with similar problems to learn that the drive motor is to blame and that repair sounds like sending good money after bad. I'm going to buy a Sony changer.
Posted on Nov 19, 2009
My teac 5 cd player wont play any cd's there has been suggestion that the laser reader is not working so how do I fix this?
It is a job for a Technician and there are no user serviceable parts inside a unit like this- people usually wreck the units as they are delicate.
The Laser pickup does not often times go bad that easily and that is just a persons way of sounding like they know what they are talking about but without substantial proof I do not just take that as fact. Many many other things can cause a malfunction other than the laser- it can be a nad spindle motor, platter distance can be wrong and can even be dust on he lense. I have working Sony decks here from 1987- these are the original pickups- same kind you have I bet.
Dec 19, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
The turntable is jammed does not rotate we have all the cd's out of it and an error code of UI comes up? any ideas how to get it to work?
1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
May 30, 2011 | Pioneer PD-F1007 301-Disc CD Changer
A homemade CD got caught in the turntable and now the turntable is stuck even after removing the CD.
Try this:1. Remove the cover (2 screws on each side & 3 in the back).
Feb 20, 2011 | Pioneer PD-F1007 301-Disc CD Changer
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
Cd disk player won't spin cd
HI, this is a basic spin motor fault. This unit will require service at this point. The actual affected motor is buried within the optical assembly, and will require a set of precision tools to disassemble correctly and safely.
Replacing this damaged spin motor will correct this issue.
Sep 10, 2009 | Teac PD-D2610 5-Disc CD Changer / Player
Teac PD-D2610 5-Disc CD Changer / Player Logo
296 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
