Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
My Campbell Hausfeld 1300 psi 1.6 gallon electric pressure washer will not sustain flow, but will pulsate where motor turns off then on continually. It's not overheated, its almost as if someone was is turning a light switch off and on.
  • n8driver2004 Nov 19, 2009
    It will pulsate when you pull the trigger. It will sometimes work fine for a minute or two right when you get started using it, but after that it will begin to pulsate when you hold the trigger.
  • Bill Phillips May 11, 2010
    With or without pressing the trigger on your gun?
  • 251 Answers
The unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
  • Garry Clelland Nov 19, 2009
    if it continues to pulsate whilst still running then one or more of the pump valves is sticking , usually dirt/grit or cleaning chemicals will cause this
Hose quik diconect replacement parts
campbell may use a propietary fitting for you to purchase from them try 22 millimeter twist type fitting KARCHER brand uses them they used widely in EUROPE.
Apr 24, 2016 | Campbell Hausfeld 1300 Psi Pressure...
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Can't seem to separate the lance from the gun. Got the unit from an estate and it hasn't been used in 2 years.
hey there...
If the lance and hose have been sitting for an extended period of time, they may have rusted inside, and are likely to cause issues when they are put back in service. Usually best to replace the expendables like hoses and guns if they have gunked up. 1300 psi is not much, but with a restricted lance nipple, you're getting 700psi...
Jan 31, 2010 | Campbell Hausfeld 1,350 Psi Electric...
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
516 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
