Question about Kitchen Ranges
My oven is not working the time u cant press any key for the oven to be on
  • 11,896 Answers
When the touchpad is not responding, it will need to be replaced. You can remove the panel to access the wires connecting the pad. You can test the power coming from the display to oven with test light, volmeter/ohmmeter to see if it responds. Chances are it is faulty. You can get parts and manual and more at repairclinic.com or partselect.com
Posted on Nov 18, 2009
How do I get my panasonic inverter microwave out of function key?
  1. Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven. ...
  2. Depending on the model if the [Timer/Clock] button are one then press this 3 - 5 times. If they are separate then press the [Clock] button 3 - 5 times.
  3. If successful, the display panel will go blank.
Dec 01, 2016 | Panasonic Car Audio & Video
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
I dont know how to set the clock on the oven, therefore I cant start the oven
It depends on the make/model of the set.
All you need is to press and hold and the clock will blink on the hour/minutes and it must be changed and set. Use the button marked clock to press to hold for setting. Change time using the 0-9 key pads by typing the correct time..
Jul 23, 2011 | Microwave Ovens
Just moved into new home and cant work out how the oven works. light flashes ''auto'' but randomley pressing buttons doesnt seem to do anything
You have to press buttons in specific order.
Try pressing the 2 on left together, and at the same time press button on right.
Pleae rate my solution.
Thanks.
Jun 14, 2009 | Belling XOU252 Electric Single Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Double oven will not switch on hotpoint ew91
Press 2 buttons at the same time on the the left of the the timer unit, and then press one otjher button on right of timer unit, this should bring it off auto setting.
Dec 25, 2008 | Miele Novotronic H350-2B Electric Single...
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Key pad not working
my n,u,c and v key is not working properly..
Dec 19, 2007 | Jenn-Air JJW8330DDS Stainless Steel...
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
