Question about GE Refrigerators
Hi, I have a side-by-side fridge/freezer. The water dispenser has stopped working and now the fridge side is warming up. Any ideas?
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
CONCERNING YOUR WATER FLOW ISSUE
First, you will need to check the lines inside the unit for ice build-up. if the lines are not frozen, this will lead to a failed inlet valve. Additionally, check the filter(IF EQUIPPED). If the filter has not been changed in a while, it may have reached its filtering limit. if so, this will stop the normal flow of fluids threw the dispenser assembly. replace the filter, if needed. if the filter is not an issue, kindly move on to the valve inspection.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Nov 18, 2009
  • Michael Masters
    Michael Masters Nov 18, 2009
    • If the valve test indicates that the assembly is ok, this will lead to a failed main control board. the valve receives its power from the main board. if there is circuit failure there, the valves will not operate.
I have a two year old samsung side by side refrigerator RSA 1DHMH. The freezer department has suddenly stopped producing ice and the temperature has risen significantly that food as now thawed. I have...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Samsung RS2534 Side by Side Refrigerator
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Fridge stop working
You need a volt/ omh meter or call a repairman.. need to start at the control board and check power going out of the board. sounds like a board problem with out more info
Sep 03, 2007 | GE PSS26NGPBB Side by Side Refrigerator
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
