Question about Sony CASSETTE DECK Single Dual Cassette Deck
Cassette door openers will not open doors and if doors are open and tape inserted neither side will run tape at play speed or ff or rew. Took off cover and seems to be no mechanical issue. There may be some type of electric solenoid that is broken and preventing cassette doors from opening???
  • kmeyer7576 Nov 18, 2009
    Model Sony TC WR565
  • kmeyer7576 Nov 19, 2009
    Thank you, checked it out and it does appear to be the problem, I ordered two new belts
  • 10,594 Answers
Model number of cassette player will help to suggest solution.
Thanks.
Posted on Nov 18, 2009
  • Shahid Electronics
    Shahid Electronics Nov 19, 2009
    Model Sony TC WR565
    Please replace belt that goes on Capstan and Motor as if it slips then mechanism wont load/ unload properly.
    Belt part number is 335941701.. BELT FLAT CAPSTAN and available in Part Store for $4
    If you are not comfortable with belt replacement as unit will be apart in detail then take it to local tv repair shop.
    Thanks.
Tape deck wont play only makes noise
The drive system is not functioning. Could be belts
Oct 19, 2012 | Sony Audio Players & Recorders
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Sony SLV-N71 VCR makes a rattling sound (ff, rew)
I make no claim to being any kind of an expert techie but it sounds to me like there are one or more loose or badly worn parts inside your machine. If you haven't had a look at the innards, try that. Loose things can usually be re-secured and, sometimes, worn parts can be replaced.
Rod
srives@shaw.ca
Feb 04, 2009 | Sony SLV-N71 VCR
Cassette door will not open
Found more issues, got top off and door open but touch controls did not move flywheel in any mode for long and internal noise. Will abandon repair as probably too costly.Thanks
Jan 16, 2009 | Audio Players & Recorders
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Feb 04, 2008 | Audio Players & Recorders
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
223 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
