Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Mac compatibility I just purchased the Seagate FreeAgent Pro, pluged it in, but nothing happened. No dialogue window opens.  Is it not compatible with Mac?
  • jchamberlin Jan 15, 2008
    I'm using a Mac also. Is there an ON/OFF switch on this HD. If there is, it is certainly well hidden. Disk Utility showed me my other three drives (two internal) but not my new FreeAgent Pro 500GB. What do I do now?
  • sitback Feb 13, 2008
    How do I setup this external drive on my G4 imac superdrive as there are no instructions given in the box except to say its easy ?? Im in disc utility now what ?
  • 667 Answers
Have you used Disk Tools to see if the drive shows up there?
Posted on Jan 10, 2008
Trying to buy seagate external compatible with MacOSX 10.4 without intel processor
ext drives can be formatted to any mac o/s so they do not come pre formatted except for pc side check FAQ's at seagate on this issue
May 31, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
My mac wont read my external
Connect it to another computer, to see if the Seagate device works at all.
If not, then disassemble the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, and install it into the enclosure, to "revive" your external storage device.
Is the manufacturer's warranty still valid? If so, exercise the warranty, to get a replacement, at minimal cost to you.
Nov 02, 2010 | Seagate FreeAgent Pro 500GB External USB...
I have purchased a Seagate free agent Goflex 500gb I want to run it with my Mac Pro note book it dose not work
For a MAC to use an external Hard drive, the hard drive has to be formatted FAT32 file system. That is the only file system MAC sees.
Jun 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hardrive 'cant be modified' on mac
since the windows and mac has different file format , u need to convert for support to mac systems
Oct 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Trying to format for MAC
I had a similar issue and was able to work around it by partitioning the drive. See this site for information:
Overview: Open Disk Utility, Click on the Drive, Click Partition, Choose the number of partitions, and click Apply.
(It's written for video editors, but is applicable in your situation)
Let me know if this helps!
Apr 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Pls. help me with my new seagate external freeagent pro ( 500GB)
hi..there....i think if you can get e sata cable to connect between external and pc at you country is very bad news..but maybe you can get it in another store...last time when i visit bangkok thailand i'm very happy because i can get all componnet for pc..i buy a internal card reader that include the e sata connection is around 400 baht and the cable connector for it (power and data cable) is around 100 baht. so if you have friend at tahiland (bangkok) you may ask them to buy it for you and send it to your place....
Feb 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
FreeAgent Drive cannot be Modified?
The problem with the compatibility between your external drive and your mac is that freeagent drives are formatted in NTFS and the Mac uses FAT32. Mac's can read from NTFS drives but cannot write to them. I'm afraid that the only solution is to re-format the drive in FAT32 format if you want to be able to write to it.
Jun 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
149 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
