Question about Toshiba Tecra M2 Notebook
Thanks for your advice experts you are the best. Okay here's my question, my sysytem is saying missing or corrupt file
  • Naomi Mahon
    Naomi Mahon Nov 19, 2009
    Thank you so much.I actually do have a windows xp pro sp2 disk which I tried to install/upgrade while I was in safe mode and unfortunately due to restart during install process, and my own stupidity in using safe mode(new news is safe mode is bad news?!) ha who knew,lol... well windows setup was incomplete and I was given this message->Windows could not start because the following file is missing or corrupt
    President:
  • 2,600 Answers
If this is keeping you from booting up below is the fix.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 19, 2009
Break in operation file is corrupt
the file you are downloading is corrupted on the file server, or there is a malware on your computer that is infecting the file as it is downloaded.. and hence the software is not able to execute properly.
call 1-877-805-1027 for expert help.
Nov 20, 2015 | Computers & Internet
Tip
PS3 Problems - Hard Disk Corruption
Hi there
Finally there is a fix for this, You used to have to send the ps3 to sony and all your hard work on your games was wiped clean,
Not anymore, the safest way to fix it and keep all your files in-tact is to use an expert repair guide.
if you have a look at this awesome website that actually gives you the best advice on the best repair guides on the web.
www.ps3problemsgone.info
on Jun 12, 2010 | Sony Playstation 3 (PS3) Console
How to fix a frozen screne
The cause of the freezing, or locking up, of your computer, is due to some either corrupted or missing files. And more specifically, missing or corrupted registry files. These are the files which tell everything on your how it is suppose to work. Basically, they are configuration files. And if these files get corrupted, or messed up, it can wreck havoc.
Sometimes the registry files end up missing. This can happen when you uninstall software from your computer. The software being uninstalled may remove registry files also associated with another program. There should be a message asking you whether or not you want to delete the files as they are associated with another program. Your best bet is to say NO to this and leave the files. If the files end up missing, then the program which needs them will stall, hang, or freeze the next time it tries to run. But there is a simple way to fix this.
By just running registry scan software on your computer, you can find these problems and fix them right away. It will let you know which files are bad, and will fix them to its original state. And it is this simple step which will show you how to fix your computer freezing.
Dec 14, 2010 | Computers & Internet
Freezing frequently ?
Dec 13, 2010 | Dell Inspiron 560 PC Desktop
I have a Asus eee 1005HA running Windows XP. When I try to boot, I get an error message saying "file missing or corrupt \windows\system32\config\system You can attempt to repair this file by starting the...
Ring this number: 0870-120-8340. You might be able to get a disk of them at Asus,if not im sure they will help you with the best possible advice---Good Luck!
Davey Snake!
Oct 25, 2010 | ASUS Eee PC 1000HE Netbook
My acer one keeps saying the following file is
My advice is to reload your windows disk to overcome this problem
Jul 15, 2010 | Acer Aspire One PC Notebook
My averatec will not boot up it state that the file is missing or corrupted. what can i do
I would tell you what other experts would say get those recovery disk out and try to repair the partition or download a $89 program www.grc.com spinright and that will find the missing file or make attempts to recover the partition.
Dont have the recovery disk? I would call the company/manufacture as its not good business practice to sale a computer without a recovery disk.
Lost them? Well the best thing I can tell you here www.ubuntu.com has free linux distrobutions. Do not like linux? Please pay $119 dollars for windows 7.
I am just clsing most of your questions before you ask them so we got a direct click on that accept button because any of these are solutions to your issue.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 08, 2010 | Averatec 6200 Notebook
this mean you window is corrupt you have to install a new window it will help you just try if it dont help send me an email i will see what is the other problem
[ ariftariq12345@gmail.com ]
Nov 18, 2009 | Computers & Internet
GMA 4082n device driver not working properly code 39
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Tecra M2 Notebook Logo
275 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
