Question about Ovens
My oven turns itself off. Resets the clock - Ovens
  • bscooky Nov 18, 2009
    It does it when it it turned on and cooking. Often when it reaches the preset temperature
  • 11,896 Answers
Very well could be a power supply which is common. You can test the power from supply to main board with a voltmeter to see if it is faulty for sure.
Posted on Nov 18, 2009
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    Ok. As long as it does turn on, then the supply is good, you are looking at a bad temp sensor. I would test it with an ohmmeter to make sure.
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
