Question about GE XL1800 1100 Watts Microwave Oven
Belt has snapped on turntable
If the belt has snapped on the turntable and it is not rotating anymore, is it something that is easily fixable or do you recommend a GE repair person be called for $69
  • 589 Answers
It's probably relatively easy to change it. The problem may be actually GETTING the silly part.
Posted on Jan 11, 2008
Turntable does not turn, Replaced Rotating ring assembly still not turning?
It may be the servo motor that powers the turntable or the belt has snapped or come off. It is unlikely that you can get to the motor as the case is fitted with security screws. If so, you will need to take it to a service engineer.
Mar 18, 2016 | GE Advantium 120 Convection/Microwave Oven
Turntable does not rotate
Have you check to ensure the motor is running if yes then check the belt to ensure it is still attached to the motor and patter. If not then you will need to re-attach the belt.
Dec 06, 2011 | Emerson Microwave Ovens
The turntable has stopped revolving
If there is heat and the turntable is not working it can be due to failure of the drive, the belt or the motor or motor drive.
Check them one by one to confirm.
Please check this link for tips to check:
Sep 06, 2011 | Microwave Ovens
The turntable on my NN-A554 microwave won't rotate, could it be the belt?
You require a new turntable motor. Easy enough to fit from underneath the cavity.
Ask a dealer for the turntable motor, they are relatively inexpensive.
Dec 27, 2010 | Panasonic NNA554 Convection/Microwave Oven
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Aug 07, 2010 | Viking DMOC205 Microwave Oven
Turntable isn't working on our microwave model PLMV168. My wife defrosted a large item that was to big to rotate and forgot to turn the turntable off. After that it quit working. Is there a belt that might...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Jan 31, 2010 | Frigidaire PLMV168 Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
LG Countertop Microwave why stopped rotating?
Microwave turntables are belt driven from a small motor.
Usually it is the belt that needs replacement.
Unplug, and remove the outer case to inspect the belt. If it is still tight and attatched, the chances are it needs a new motor - often it's cheaper to buy a new unit.
Sep 04, 2008 | LG Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Jan 10, 2008 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
82 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
