Question about Philips 60PP9200D Television
I have a pretty good pic through the a/v inputs, but not through the HD side. The pic is hourglass shaped and will not respond to any adjustments to attempt to fix it. My local TV tech has tried entering a code and adjusting it there as well with no luck, nothing responds. I have tried to wait for him to get back with me but after several months of telling me he'll get to it, my patience are wearing out. I thought I would explore any other options.
  • 3130 Answers
SOURCE: convergence adjustments codes with remote control
If your talking about a service menu, NEVER ever unless you have the service manual, go into the service menu and change anything to try to fix a problem the service menu is there to adjust sets at instalationsd and not when a problem, occours and when theres a smell. common sense tells you something is wrong and burnt up. So how is a service menu that you have no clue what to do with going to help you fix a set? Im sorry man but wake up and smell the coffee. what makes you a service tech after your set breaks down.,. Oh by the way there is NO such thing as a "CODE" to fix anything in your set. There is a service menu with settings to adjust things like convergence and vertical and tunning of channels, ect ect. Get a manual and follow it if you want to try a "code". you can get one at http://www.service Then you will need to call a tech as your set is a solid state set with No user replaceable parts inside them. Please dont risk your life trying to fix a TV set as there is a lot of High Voltage inside these sets even when they are unplugged.
Posted on Sep 13, 2006
  • 5138 Answers
SOURCE: Have a 60 inch Philips HDTV, model 60pp9200.
Replace Both of your STK iCs big black ICs example STK392-110 Call Mats for Parts 1-800-628-1118
Posted on Dec 16, 2009
SOURCE: Cloudy picture on Philips Rear Projection TV
Hi - I have been searching the internet for the same solution myself as I have a Thompson projector - most solutions refer to addressing bacteria in the "tv coolant" - however I simply removed the screen and found the colour lamps and rear mirror to be covered in dust. I wiped both (with a duster only) and the picture improved by 100 per cent.
Posted on Jan 03, 2010
  • 170 Answers
SOURCE: The color is off in the tv. The color green has a
replace light engine (optical block)
Posted on Sep 24, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a Philips projection screen hd tv great picture but the color is way out off adjustment
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
Posted on Oct 30, 2011
My picture is hourglass shaped near the edges. is there a way to adjust this?
sounds like a keyway setting issue i dunno if your tv has has a setting to adjust this so you might need shop call to adjust this
Nov 17, 2010 | RCA P52960 52" Rear Projection Television
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
Hourglass Picture
can you please identify the unit model/maker
Jul 08, 2008 | Primax Electronics HT2778P TV
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Hourglass shape on screen
you might tyr adjusting the eprom setting to correct the e/w pincushion fault,or call for service to adjust.
Nov 06, 2007 | RCA 32F531T 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Hourglass shape on left and right side-ballpark repair price please
The shape your seeing is called 'V Bow' and 'Pincushion' which needs to be calibrated again. Theres probably a diode that went out. The tech can open it up and adjust the angles back. I wouldn't charge over $100-$150. Shop around for a good repair tech. Good Luck poe_diddley.
Jul 13, 2007 | Samsung TXN3071WHF 30" TV
Hourglass shaped red
I need to see a picture of the TV set. send a photo to
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Picture is hourglassed shaped
your unit has a problem in horizontal circuit particularly deflection and pincunshion circuit. pls have it check by a qualified service technician.
Jan 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Philips 60PP9200D Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
