My Hyosung GT250R makes a buzzing noise (coming from the relay) when I try to indicate right (the indicator lights remain off). However, the left indicator works perfectly. Any ideas what is wrong? Thanks. Ross.
It sounds like:
1) One of the wires that takes power to the right hand turn signals is shorted to the chassis.
2) One, or both, of the right hand turn signal bulbs is burnt out.
3) The turn signal switch has failed.
Testimonial: "Hey Wayneman, The rear indicator bulb was burnt out. Problem solved. Thanks so much. I really appreciate it :) Cheers, Ross"
Hi, this is not a solution but I have a lated question to the topic.
When I turn on my signal indicator, it showing that both of the left and right hand flashes (just like hazar indicator) but somehow only the right light actually go off, nothing on the left. Do u know and ideals is going on? The relay making this really loud noise, and its the hazar relay that going off, which one is the signal relay? Thanks in advance. Sean.
I just had this problem, 08 hyosung gt250r
Right indicators worked fine.. left side wouldn't work and the box would buzz..
Turned out to be the rear indicator itself shorting out.. swapped with one I had laying around and fixed it..
If you don't have a spare laying around see if you can swap the plugs around.. plug left into right and right into left..( not much room to work but i did it)
And if does it backwards now that's ya problem..
Cheers
