Question about HP Office Equipment & Supplies
Have a hp laserjet II P printer. paper feed not
Have a hp laserjet II P printer. paper feed not working properly. takes about a half sheet then starts crumpling it because somewhere in the path the paper gets blocked or the path is not clear???????? Help
  • Hank Mikec Nov 21, 2009
    Checked all the gears. No appararant damage. turned drive gear that is off the motor and everything seems to be moving when it is supposed to. Put in new toner cartridge. seem like wh5en the paper reaches the cartridge it stops moving and jams. Don't know!!!!!!!
    Problem Solver:
  • 7 Answers
Drum drive gear is broken that is why it is jamming
Posted on Nov 18, 2009
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
Apr 14, 2014 | HP LaserJet P3005 Printer
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
PAPER WON'T FEED PROPERLY. GRABS SEVERAL SHEETS
You need a seperatin pad, sub pad kit and new feed roller.
May 20, 2010 | HP LaserJet 1100 Printer
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
Apr 05, 2010 | HP LaserJet IIIp Printer
Single sheet paper on my HP LJet 1100a works fine
There is a recall fix on this printer if it has specific feed problems like pulling in multiple sheets etc. Might be related. You can contact HP and they'll send you a DIY fix kit to replace the rubber that pulls the sheet in and onto the rollers.
Feb 07, 2010 | HP LaserJet 1100 Printer
Laserjet 4MP paper jam problem Half feeds from
I have seen this issue before and your problem is likely due to very fine paper dust on the pickup rollers. This is easy to fix and takes only a few minutes. Use a soft piece of cloth (not a paper towel), a computer cleaning towelette or anything that does not produce lint; dampen it (unless your are using a towelette) slightly with cleaning alcohol and wipe off the paper pickup roller on all sides. You should also remove the toner cartridge and vacuum out the interior of your 4MP, use care if you are not used to poking around the interior of HP printers. You will usually find both white paper dust and maybe some black toner dust. Put the cartridge and paper tray back in place, print a couple of blank sheets as a test - you should be good to go.
Oct 03, 2009 | Office Equipment & Supplies
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
LaserJet 1020 printing solid black pages
1.replace the cartridge.
2. check PCB board contacts
3. replace PCB board
Jun 19, 2009 | HP LaserJet 1020 Printer
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
