Question about Samsung HLN437W 43" Rear Projection HDTV
TV Screen 'freezing' while watching.
I have a Samsung DLPTV Model# HLN437WX/XAA. My problem is that while watching TV...out of nowhere the TV screen will 'freeze' into a grayscale image. The sound continues. The remote will not turn the TV off so I end up unplugging. I'll turn the TV on again and it will work for a short period of time before it happens again. (The TV has also worked for a long period of time before this happens). What is the problem?
    President:
  • 1,284 Answers
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Posted on Nov 19, 2009
Can you replace a fan in the samsung DLPTV model #hln437wx/xaa
it has 2 or 3 fans---they rarely fail but can cause issues---Are you hearing a high pitched whine or fan like sound? I KNOW WHAT THAT IS IN THIS SET...
Apr 09, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I got this tv (Samsung #hln437wx/xaa) used recently as is. I'm familiar with this type of tv as I own a Mitsubishi wd-52628. Problem:Before even powering-up the tv, I removed the lamp checking if it...
There is a power supply that supplies the circuit board plus the lamp, because of hi power there may need someone to look at the circuit board and maybe repair it
Should not cost that much
Aug 09, 2010 | Samsung HLN437W 43" Rear Projection HDTV
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
Samsung hln437wx/xaa will not turn turn temp and lamp laights flashing
either the lamp is burned out or the Ballast for the lamp is blown.
Oct 27, 2009 | Samsung Televison & Video
I have a Samsung HDTV. Model Code HLR4667WAX/XAA,
IT'S YOUR DMD MODULE IT'S PART OF LIGHT ENGINE IN THIS PATICULAR MODEL WHEN THAT GOES BAD YOU HAVE TO REPLACE WHOLE LIGHT ENGINE CONTACT DISCOUNT MERCHANT OR RIVER VALLEY ELECTRONICS THEY HAVE THEN FOR PRETTY CHEAP.
Jun 24, 2009 | Samsung Televison & Video
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
281 people viewed this question
Jerry Greenberg
Jerry Greenberg
