Question about Cell Phones
How do i hard reset the lg lg9100t
How do i hard reset the lg lg9100t please help
Lg l34c sreenlock password how to hard reset. Volume up or down plus power button does NOT work. Help !!!
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 27, 2016 | LG Cell Phones
Lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
May 14, 2016 | LG G4
Hard reset lg e739
LG E739 hard reset
LG T-mobile myTouch E739 reset If you can't recall your unlock Pattern:
When the phone is turned off, press and hold the Power/Lock + Volume Down.
After 3 seconds press
Back and Menu keys.
WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset.
Source: http://www.hard-reset.com/lg-e739-hard-reset.html
Jan 15, 2014 | Cell Phones
LG GT540 Cell Phone "sorry the process com.android.phone has stopped unexpectedly. please try again"
Ok, I would say to reset your phone by code, just dial
  • Dial 3845#*54#
  • Now select Factory reset
But obviously it won't work because Android is corrupted.
I will leave this link which will explain how to hard reset your phone without using Android, and I hope it works. Hard Reset LG GT540 Swift
Jun 28, 2017 | LG GT540 Cell Phone
Hi can i get unlocke code for lg-p500h telus to rogers
try this code 2945#*# and perform factory reset and default code is 0000 or 1234, if problem persist, try to hard reset device pressing power+home button+volume down for 5 sec. but before do that make backup because the hard reset will delete all data.if my answer was helpful please rate.
Jul 04, 2012 | LG P500 Cell Phone
How to unlock or reset secret folder code in mobile lg gx 200 or hard reset the mobile so that my passwords will reset, i've forgot my password, please help me
This article explains various solutions for recovering access to your Yahoo mail account.
Please note accounts that have had absolutely no activity in the past 12 months are at risk of being deleted.
Abandoned and obsolete accountsare often quickly deleted from the server, making account recovery impossible.
Forgot Yahoo ID
If you have forgotten your Yahoo ID, head over to Yahoo'sAccount Recovery Wizardpage.
Follow the step-by-step instructions to recover your account information. Reset a Forgotten Password
Use theSign-in Helperto reset your Yahoo password and regain access to your account. For account security,
Yahoo only displays some of the options below. The system determines which options to display
based on factors like where you're signing in from and recovery info on your account.
Change, recover, or reset your Yahoo password (Partner Accounts)
Your Yahoo password gives you access to every Yahoo service you use.
You'll need to know your current password in order to change it to something else. If not, you can reset it to start fresh.
Partner account- If you have an email account with Yahoo through one of with partners (Verizon, AT&T, Frontier,
Rogers, BT, Sky, Spark, or MTS)
follow these instructions to change or reset your password.
Change your password
Go to the Yahoo Account Info page.
(Mobile web browser only) tap the Menu icon Image of the mobile web version of the menu icon..
Click Account Security.
Click Change password.
Enter and confirm your new password.
Click Continue.
- A confirmation appears.
Click Continue to finish.
Reset a forgotten password
Use the Sign-in Helper to reset your Yahoo password and regain access to your account. For account security,
we'll only display some of the options below. The Yahoo system determines which options to display based on factors
like where you're signing in from and recovery info on your account.Mobile phone number and alternate email address.
·Go to the Sign-in Helper.
·Enter your phone number or email address.
·Click Continue.
·If prompted, enter the CAPTCHA code.
·If you can receive text messages to the number listed, click Yes, text me an Account Key.
If you have access to the email address listed, click Yes, send me an Account Key.
·Depending on the option you've selected, Yahoo will send an Account Key to your phone or email.
·Enter the Account Key that Yahoo sent in the field provided, then click Verify.
·Select an account to reset from the list connected to your mobile number or email address.
-If you see an account that's not yours? You can remove it by clicking remove it here.
·Click Continue.
Forgot Yahoo Password Use Your Secret Questions
Note: If you don't have secret questions on file, that reset option won't be available in Sign-in Helper.
Also, remember thatthe system will determine which if the secret questions will be made available to you.
If you have forgotten your Yahoo password and wish to use your security questions, head over to Yahoo'sContact pageand selectPassword and sign in.
Under sub-topic two, selectForgot Password, underRecommended Option, enter your email address and click onSubmit.
ClickNext. If prompted, enter the CAPTCHA code.
SelectUse my secret questions, followed byNext. Then enter the answers to your security questions.
If entered correctly, Yahoo will prompt you to enter a new password. Enter your new password and click onNextto finish your password recovery.
Forgot Secret Question
·Go to the Password Helper.
·Enter your email address.
If you have a mobile number, listed on your account, that option will show it.
·Click No, I can't receive text.
You'll see your alternate email address.
·If you have access to that email, click Yes, email me.
A "Recover access to your Yahoo account" email will be sent to your alternate email address.*
·Enter the verification code Yahoo sent you, then click Submit.
·Click Continue or you can click Create new password and update it on the spot.
Important Note: If you can't answer the secret question andyou do not have access to your alternate e-mail address or phone number,
there is nothing else you can do as Yahoo is not able to tell that you are the legitimate owner.
Invalid ID or Password Message
If your attempts to log in are being met with anInvalid IDorInvalid Passworderror message,
this signals that you've entered a password and Yahoo ID combination that doesn't match what's on record.
If you're sure that you're entering the correct sign-in information, there are a few scenarios as to why this is happening.
If your password contains numbers or letters, make sure that yourcaps lockornumber lockkeys are activated as needed.
Case-sensitive passwords are often entered incorrectly due to key stroke sensitivity.
Take a look at your browser'sauto-fill settings. If your browser usually enters your password for you automatically
and you've changed your password recently, you'll need to enter your new password manually to override your browser settings.
If you're sure that you're entering the correct information, this could be a sign that someone else accessed your account and changed your password.
Change your password immediately using the Password Helper tool. Once you regain access to your account,
review the steps to secure a hacked account to undo any changes made without your knowledge.
Alternate E-mail or Phone Number Changed
Head over tosign in helper.Use the sign in helper and attempt to recover your account,
if you still can't access your account, read: Your Account Recovery Information is incorrect below.
E-mail providers take your account's privacy and security very seriously,
and we'll only let you reclaim an account if you can prove you're the rightful owner.
When you register for an account,it's up to you to provide the most up-to-date and valid recovery info.
Your best option to avoid losing access is to update your recovery info
if you get a new phone number or change your alternate email address.
If the Password Helper says my password can't be reset online -
If you've tried using the Password Helper and weren't able to get access to your account,
other recovery options may not be available. We know it can be frustrating to see the fail page,
but in these rare cases, we recommend creating a new Yahoo account.
Find your Yahoo ID and restore access to your Yahoo account
From Your Desktop Computer
·Go to the Account Recovery Wizard. Or Forgot Yahoo Password
·Enter one of the account recovery items listed in the Account Recovery Wizard.
·Click Continue.
·Follow the instructions given in the Account Recovery Wizard.
From Your Mobile Device
·On the Yahoo sign in page, tap Trouble signing in?.
·Click Continue.
Signing in From a Different Device
If you've recently changed your phone or your mobile SIM card, you may see a verification message upon
your first log-in readingFirst time signing in from here?
When you see this message, you'll need to choose whether you want to verify using your phone or alternate email address.
Depending on what you have listed, you can choose to get the code through text message, a phone call, or an email.
Click on the method you'd like to use and then check your email or mobile phone for the verification code.
Enter the code in the field provided and clickSubmit.
For further information, click on thislink.
Yahoo Mail Account Locked
To protect your account, a temporary lock is triggered anytime there have been too many unsuccessful attempts to sign in.
The lock will be lifted automatically after 12 hours, but you can always regain access to your account immediately using thePassword Helpertool.
Problems Using Yahoo's Account Key
Yahoo Account Key is used to "make your life easier". Its goal is to avoid the use of password which is replace by an authentication made with the mobile app.
But, if you can't use your mobile app (network issue, lost phone,...), you can follow these steps:https://help.yahoo.com/kb/SLN25921.html
Problems Using Yahoo's Password Helper
Yahoo takes your account's privacy and security very seriously. As a security measure, Yahoo will only let your reclaim an account
if you can definitively prove you're the rightful owner.
Since Yahoo does not collect much information up-front when you register, there are limited options for verifying that you own an account.
Your best option to avoid losing access to your account is to make sure that your account recovery information always stays up-to-date.
When the Password Helper says that your password can't be reset online - If you've tried using the Sign-in Helper and weren't able to get access to your account,
other recovery options may not be available. We know it can be frustrating to see the fail page, but in these rare cases,
Yahoo Account Has Been Hacked
If your Yahoo account has been hacked, clickherefollow the prompts.
Yahoo Customer Care Personal Contact
To date, Yahoo has not given any way to have any personal contact with customer care.
You must therefore try to recover your account through the means provided on Yahoo site.
https://yahoopasswordssupport.freshdesk.com/support/solutions/articles/42000013544-how-to-reset-yahoo-password-forgot-yahoo-password-solution
Sep 30, 2011 | LG Cell Phones
Forgot lock code on a LG VN270 and want to hard reset it. Can not access any menus in the phone is there a way to reset it using the keys?
Hi, the LG VN270mobile phone cannot be hard Reset without you Unlocking the phone and the only to unlock the phone is to get the unlock code from the operators using your phone IMEI no which can be gotten by dialing this code (*#06#) on your phone and copy out the numbers that appear.
To help you get your unlock code,visit the link below
http://sim-unlock.net/sim-lock/5/Unlock_by_code_for_any_LG
To help On unlocking the phone,please follow these procedure
get a sim card to enter your unlock code,
Enter Unlock sequence mode 2945#****# where *** is the model of LG phone numbers, for example, for VN270 enter 2945#*770# and a hidden menu where you can enter the unlock code you purchased earlier and your lg phone is back and you can perform a hard reset.
please contact me if you need any more help about hard resetting the phone. Thanks
Sep 16, 2011 | LG Cell Phones
How to hard reset LG GW520? The phone starts up and come yo frozen screen. Thanks
Type for soft reset *#7780# . For hard reset *#7370# If it as default 1234
May 20, 2010 | LG GW520 Cell Phone
How can i reset my lg ks660 to its original setting
i have an LG KS660, i want to hard reset to it. do anyone know how to do the hard reset for that. I tried doing RESET SETTING, but with that the phone is not coming to its original settings. Any solution with anyone ??
My email: sfanjj@yahoo.com
Mar 29, 2010 | LG KS660 Cell Phone
Cell Phones Logo
1,269 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
