Question about Cell Phones
Laptop will not turn on without being plugged in.
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
I am guessing the battery has not charged up, leave the unit over night charging and try again, if it still will not start with just the battery I believe it is dead. Also try starting the unit with the battery out - does this happen, if yes then battery at fault
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 18, 2009
  • 4,102 Answers
Hi, the problem you are having is going to be either the battery is totally dead you should have got some warning about this on your lap top as the battery's have only a certain life span before they need replacing so this is the most likely cause of your problem.
If its not the battery then you need to start thinking about the wires going to the battery may have come loose this is less likely as the lap top wouldnt come on at all even with power lead as the power goes through the battery.
Get the battery looked at and changed this will then solve your problem.
Let me know how you get on or if you need further assistance ok.
Many thanks for using fixya.com
Please pass this website onto any friends and family members and the experts here would be more than glad to offer any assistance with any tech problems
Acer aspire 5100 when a laptop does not start with power plug on and no battery what could be the issue
Do you have a voltmeter? The first thing I would check is to see if you are getting 19VDC coming out of the charger. The on then off when you have the battery in sounds like your battery is almost out of juice and the fact that nothing happens when you plug it in without the battery indicates to me that your power adapter is not working.
Jan 31, 2017 | Acer Computers & Internet
Laptop without battery turns on at one plug socket but not another plug socket, i'm confused???
Sounds like there must be enough of a difference in the quality of the power at the friend's house that makes a difference to the laptop.
Unfortunately the meters are very expensive:
Extech 382090 3 Phase Power Analyzer Data Logger
Jan 02, 2015 | Samsung Computers & Internet
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
My laptop doesnt turn on at all..help
Turn on your laptop without power adapter but with laptop battery. Or remove your battery then plug your power adapter then try turning on. If it's not turning on your motherboard damaged.
Please rate me!
Nov 25, 2010 | Computers & Internet
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
With power cord plugged in and without power cord plugged in the pc will not turn on
remove the battery, plug-in power cord then power on. your battery may be completely drain and your power adapter can't give enough supply to power up your laptop and charge the battery at same time. if doing so power on your laptop, charge your battery for about 12 hours without turning the power of your laptop
Nov 03, 2009 | ASUS EEEPC901-GP010X Netbook
Notebook plugged in. cannot get the dell to turn on. its not the power suppy that i plug into wall
1. remove all ext peripherals
2. remove battery
3. plug ac adapter to wall socket power (without the laptop)
4. check if the ac adapter led stays on, if yes then connect the laptop, check if the ac adapter led turns off after connecting to laptop, if not then turn on the laptop if still no power then have replace the motherboard.
Oct 15, 2009 | Dell Precision M60 Notebook
Problem with distrubing power to my HP dv6700 laptop!
You may have more than a dead battery problem, but possibly a problem with the ac adapter or the internal psu. Does this only happen with you try to use the laptop with the battery removed? or does it fail to turn on with or without the battery snapped in?
Jun 09, 2009 | HP Pavilion dv6000z Notebook
Laptop shut off without warning
try removing the battery without the ac adapter plugged in then plug it in and turn it on hope that helps.
Jan 15, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Cell Phones Logo
63 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
