Question about Acer Aspire 5315 Notebook
I lost my recovery disks during move now i cannt reboot system theres a problem on hdd it says no room left so now wont let me make any recovery disks yet there is nothing on hdd
    Brigadier General:
  • 10,406 Answers
Start Internet Explorer.
Click Tools.
Click Internet Options.
Click Delete Temporary Internet Files.
Close Internet Explorer.
Click Start.
Click Run.
Type CMD and press ENTER.
Type CD LOC and press the TAB key and then the ENTER key.
Type CD TEMP and press ENTER.
Type ERASE * and press ENTER.
Type Y to confirm that you want to erase everything in this "temp(orary)" folder.
Type CD \WINDOWS\TEMP and press ENTER.
Type DIR and press ENTER.
You should see something like:
20 File(s) 3,165,781 bytes
20 Dir(s) 1,443,053,568 bytes free
i.e., where 1.4 Gigabytes is enough space to hold about 2 full CD-ROMs of data.
Find a USB memory-stick that is mostly "empty", and connect it,
to create more "available" disk-space, e.g., 1 or 2 or 4 or 8GB more.
Now, try to make the recovery disks.
Posted on Nov 18, 2009
Removing recovery from hard disk
It is most likely that installing "recovery" on a HDD has made the drive a system drive. A system drive by definition is a drive that will boot during startup. Also "recovery" is many times a separate partition on the HDD. The simplest way to fix this is remove any data on the disk that you want to remove the "recovery" from. This next process will delete all data on the drive.
If possible install the drive in your working PC. Check to make sure that the PC has booted from the main drive and operating normally. Under computer you should see the HDD containing the "recovery"
Right click and select format.
Dec 30, 2015 | Hard Computers & Internet
How to repair a satellite toshiba p205-s7806 disk error
Toshiba won't sell you a Factory disk? ODD? If it's a HDD failure or a hardware failure, a Restore/Recovery will not help. If you have Restore turned on, restore to a date before this issue. If you have a Factory Recovery Partition, you can do a System Recovery, keep in mind ALL your data will be lost. You can find a Restore/Recovery procedure here: http://www.ehow.com/how_8012461_toshiba-p205-recovery.html
Apr 19, 2013 | Computers & Internet
Non system or system disk error
Bad HDD? Have you tried a system restore/recovery. Reboot, at preboot repeatedly tap the F-11 key try to get to system restore/recovery.If it's an old machine you may need to replace the HDD.
Nov 06, 2012 | Compaq Armada M700 Notebook
How to restore without rebooting
You will need some sort of recovery disk or the Operating System disk to do a restore. Unfortunately there is no way to do a recovery without a disk.
Oct 20, 2012 | Gateway SX2855UR20P Desktop (Black
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
Restore Partition C: of HDD without changing current partition size
CAUTION:
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
CAUTION:
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      NOTE:
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
I have an Acer Aspire x1700 and it will not reboot, I cannot locate the reboot disk. How can you help?
Yuo need a lot of try and error to be successful.
First your OS and the BOOT disk that comes with your machine.But if you dont had the CD you need to buy and download it.
Store like Bestbuy,CompUSA,etc.. sell this CD,s or go to this LINK where you can buy it online and download it, choose your OS and any other specs about your System.
After all you need to BURN the files in a blank CD or order for mail shipment.
Then we going to BOOT the system id the CD drive.
To rebuild your hard drive, do the following:
  1. Power up your Acer system.
  2. When prompted (after memory testing completes), press CTRL + ALT + ESC to enter CMOS setup.
  3. At the CMOS Setup screen select Advanced BIOS Features
  4. Verify the Boot Options Sequence is set to the following order:
    1st [CD-ROM]
    2nd [Floppy Disk]
    3rd [Hard Disk]
  5. Insert the Acer System CD, DISK 1 in your CD-ROM drive.
  6. Press F10 to exit and save. When prompted, Do you want to save CMOS data?, select [Yes], then press ENTER.
  7. The system will reboot from the CD-ROM. After booting from the CD-ROM, you will see the Acer Hard Drive Rebuild options displayed.
    Note: Use your mouse for choice selections during the HDD recovery process. The mouse will respond slowly during this procedure, DO NOT press the Enter key. Pressing the Enter key will cause the HDD recovery process to terminate.
  8. Select HDD Full Rebuild and follow the on-screen instructions.
  9. When prompted to insert Acer Recovery CD, DISK 2, wait for the CD-ROM to eject DISK 1.
  10. Close the CD-ROM tray and click OK. The system will continue to rebuild the hard drive back to factory load.
After being prompted to remove disk and restart system the unit will load system software and hardware. During this process the system will reboot several times.
Your Microsoft Certificate of Authenticity (COA) ID number will automatically be entered for you. Should you need this number for any reason, look for your Microsoft Certificate of Authenticity (COA) ID number on the cover of your system.
"thumbs and post back!"
Oct 24, 2010 | Computers & Internet
Toshiba a15 s127 laptop message "missing operating system". Tried to reboot using recovery cd. Began okay at first, but then got message "Disk (E) Cannot format primary DOS partition-Bad system area" Does...
You either have bad sectors on your HDD or the recovery CD is scratched. If your recovery CD is clean and not damaged then a new HDD should resolve your problem.
Hope this helps,
www.PuterCare.com
Jul 06, 2010 | Toshiba Satellite A15-S127 Notebook
Trying to put a recovery disk on my pc for the acer aspire one. problem is my pc is not taking this disk i have tryed rebooting from the cd but nothing can anyone help please
Is the system running MS Vista? I had this problem with a PC the other day. What I ended up doing was using an XP disk to format the HDD, then before I rebooted I ejected the XP disk and insterted the recovery disk. When the system rebooted, THEN it booted from the recovery disk.
Oct 05, 2009 | Acer Aspire One A150-1006 Notebook
Deleted Vista Recovery Partition. Now XP installer can't read HDD
if you have created recovery disk before the deleting of the recovery partition u can format the drive from your bios and create a new recovery partition using the recovery disk if not if your pc has crashed and your recovery partition is gone u will have to get a new operating system software but if your pc is still stable just run the recovery manager and restore to factory settings and it will put recover partition back on your hard disk
Feb 04, 2009 | Computers & Internet
Hard disk wont start
probably hardrive is defective. However you can enter the BIOS and revert the settings to default and test again. Also perform full power cycle. If issue persists I recommend you to replace/service your HDD.
Good Luck
Jan 31, 2008 | Dell Inspiron 1000 Notebook
Acer Aspire 5315 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
