Question about Craftsman 4 Cycle Blower/Vac
Will not spark plug
Will not fire
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
No fire to the spark plugs
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
Feb 23, 2012 | 1993 Honda Accord
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
Craftsman 4 Cycle Blower/Vac Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
