Question about Imation Products - imation - Clip Flash Drive, 8GB - Sold As 1 Each - Carabiner clip. - Simple to tr... Hard Drive
8gb TDK trans-it flash memory is invisible
I tried to set up a password for my 8gb TDK trans-it. After that my flash-memory desappered. The problem is that my PC does'nt show that flash memory is connected to the usb, flash is just "invisible". I found a link to the program that resets password, but I still have the same problem - TDK memory is "invisible".
  • 358 Answers
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Posted on Nov 19, 2009
  • Imation Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Jan 27, 2012
I follow the instruction on how to use the TDK Trans it 8gb usb password, first I do resizing the partition then hit ok then suddenly there is a error in formatting the drive. Try to disconnect and connect again the flash drive accessing the program now it comes with the password that I haven't done it yet for the first time. Then try to observe and it behave badly error and error try to use some password 2005 nothing happen. Please help I just want to make it a normal 8gb flash drive without the password anymore.
Posted on Jun 08, 2011
I have a key TDK TRANS-IT versio 2.16 since 2008 and I can not access the secure because I do not know ANCI password. I am on my 7th attempt. Can you help
HI ,
If you go online annd google password recovery , it will give you a list of programs you can download to get your password ....................Good Luck Roy
Sep 04, 2011 | TDK (CD-RW74HSFXS5) Storage Media
I have a TDK 8GB , i lost my password , so i cant access to entire space on my disk,how can i totally format my flash memory?
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps Thank you
Jun 09, 2011 | TDK (CD-RW74HSFXS5) Storage Media
I have 8gb flash drive (trans-it) it can only hold 4 gb iso files
Check if there is any data on the drive you have not deleted - including hidden folders.
Dec 20, 2010 | TDK (CD-RW74HSFXS5) Storage Media
The flask card was formatted and the lock too.
TDK-branded USB drives with built-in TRANS-IT security.
"Flash Lock" password system security:
TRANS IT USB Password protection software (english)
Feb 02, 2010 | Electronics - Others
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Only 5GB on TDK TRANS-IT USB 2.0 Flash Drive 8GB
Not the solution you might like but there have been reports of bogus/ counterfeit smaller capacity sticks/drives relabeled and programed to report higher capacities. I've been told that running a formatting/partitioning application on them reflect the true capacity but have not had to try this solution myself..
Submitted for information only but please rate so I accumulate a lot of unanswered solutions, Thanks
Mar 15, 2009 | TDK (CD-RW74HSFXS5) Storage Media
TDK usb flash drive 8GB can not hold more than 5GB
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format Flash Drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | TDK (MF2HD50PK) (50 Pack) (TDKMF2HD50PK)...
Tdk trans it 4GB secure area missing
hi sir
sir my flash automatic write protect . tdk 2 gb
Sep 19, 2008 | TDK (CD-RW74HSFXS5) Storage Media
Locked out
http://www.tdk-media.eu/downloads/trans_it_usb_password_pr_english.exe
Oct 20, 2007 | TDK (CD-RW74HSFXS5) Storage Media
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
See all Imation Products - imation - Clip Flash Drive, 8GB Questions
Imation Products - imation - Clip Flash Drive, 8GB - Sold As 1 Each - Carabiner clip. - Simple to tr... Hard Drive Logo
1,110 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
