Question about DeLonghi PAC85 Portable Air Conditioner
My PAC25 had a burning smell come from the unit and now when i turn it on i hear the hum of the compressor trying to turn but nothing else happens. it is a few years old and out of warranty so is there something i can do?
  • jr2608 Nov 21, 2009
    the compressor is still trying to start so im sure the burning smell was from the capacitor but i cant find it !! I have replaced capacitors before in other machines but there isnt anything inside that i have seen which looks like one.
  • Shane Seaman May 11, 2010
    If you are smelling burning then I would be pretty sure that the compressor is gone. However, you can try opening the unit up and firstly confirm that all the wiring is good and there are no burned or short circuit wires. Then locate the run capacitor and replace it with same.
  • 41 Answers
The burn smell is the fan motor cooking. I have the same unit and upon strip down the motors windings were fried. Now that hard part of finding a replacement.
Posted on Feb 14, 2010
1998 Duo-therm Brisk Air compressor not coming on. Smelled of burnt electrical when first happened. How do I check to see what the problem is?
Burnt smell is not a good sign. If your compressor is not turning and the clixon does not shut off power you will hear a humming sound and start smelling as unit burns it self up. Chances are your compressor has seized and needs to be replaced.
Jun 11, 2016 | Brisk Air Heating & Cooling
Refrigerator clicks then hums but does not get the compressor going. Bad compressor - how do you test if starter switch or compressor?
The clicking sound you hear is the overload relay trying to start the compressor. The humming sound is the compressor. Purchase a overload relay kit. Unplug the unit. Remove the bottom back cover. On the side of the compressor is a black box. Usually held on by hard wire clips. Remove the cover. Inspect for burned wires. Take note of the relay components. Remove them and lay them out in the order and orientation in which they were removed. If you see burn marks on the you have a bad relay, also the white 'V' shaped component - shake it. If it rattles it is bad. Replace with the new overload. If everything looks good. With a multi-meter measure the Ohms across the three pins on the compressor. You will get One high reading. Across the other two you will get lower readings. The two lower readings when added together must equal the high reading. If they do not you have a bad compressor. To replace a compressor is a major repair. The cost is usually $600.00-$750.00.
Rule of thumb; "If the repair cost is 1/3 or more of your initial purchase price of the unit - Buy a new unit".
Oct 21, 2014 | Maytag Refrigerators
My unit was cooling yesterday and stopped today i put my gage it was 0psig i found a leak on the condenser fix leak and notice the condenser was so hot and not running not even humming.What next iam an...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season.
Jun 16, 2011 | Heating & Cooling
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
WASHER WILL FILL WITH WATER, BUT WILL NOT DRAIN
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Speakers humming. No reception.
The audio amplifier in the unit has failed, and that's what you smell. Turn it off and quit using it immediately - it presents a fire hazard. It might be possible to replace the bad parts. Depending on what it cost, you might want to take it somewhere for a repair estimate, but be prepared to learn it might not be fixable. Often the burned parts damage the circuit board as well.
Usually this happens in small stereo systems because of running them at high volumes for a long time. If you want to listen to loud music, you would be better off putting the money into a higher-power system.
Dec 08, 2008 | Audio Players & Recorders
DeLonghi PAC85 Portable Air Conditioner Logo
383 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
