Question about HP Photosmart 3210 Printer
Local shop says my hp 3210 has fault with ink purging mechanism and cannot be repaired is this true!
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
They can be repaired but the problem is the cost these days, to do the job is more than what the unit is worth. sorry
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 18, 2009
    Brigadier General:
  • 10,406 Answers
Probably, it is true.
You could spend $60 at a different local shop, to get the same diagnosis, or you could invest that $60 into buying a new HP printer.
Try to buy one that uses the same ink-cartridges as your current printer.
The repair shop I took my HP Photsmart 3200 All-in-One to told me the print heads had been destroyed by using refilled ink cartridges from Office Max and that the print heads were NOT replaceable, that I...
The print heads are not replaceable unless you know what you're doing. Even if you did know what you're doing, you need another bad printer of that series to exchange the print heads. It is easier to just buy a new printer that uses the same 02 ink you're used to, especially if you have a CISS system.
Oct 05, 2010 | HP Photosmart 3210 Printer
I'm getting an error 0xc18a0001 on my hp 3210 printer. What does it mean? How do i fix it?
That code indicates the the printer has the "Ink System Failure" error. This is usually reset-able. That error is normally caused by air in the ink cartridge system. To clear the error you will need to do a purge. We have a free complete guide to perform the purge at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 15, 2010 | HP Photosmart 3210 All-In-One InkJet...
Will print one copy and then says ink systen has failed unalble to copy,fax or print error 0xc05d1381
The "ink system failure' is caused by air in the ink feed tubes. This happens if you fully run out of ink in a cartridge and the printer sucks up air instead of ink or if you use a poorly filled ink cartridge that has air bubbles. You will need to do a ink tubes purge routine to clear the error. We have a step by step guide to perform the purge posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The procedure takes about 10 minutes to complete.
Buddy
Corporate Computer
www.ccl-la.com
May 18, 2010 | HP Photosmart 3210 All-In-One InkJet...
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
"ink system failure Error: 0xc19a0003"
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 19, 2009 | HP Photosmart 3210 Printer
Error 0x18a0001 Ink System Failure on HP All in one... can it be fixed?
The "Ink System Failure" error is causes by air in the ink feed tubes. This is usually caused by empty or refilled cartridges. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
Buddy
Corporate Computer
www.ccl-la.com
Dec 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
Ink systm failure on HP photosmart 3210 error 0xc18a0501
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair page link and then the HP link. Follow the steps and you should be back printing in no time at all.
Buddy
Corporate Computer
www.ccl-la.com
Oct 30, 2009 | HP Photosmart 3210 Printer
Ink System Failure Error:0xc18a0107
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
Buddy
Corporate Computer
www.ccl-la.com
Oct 23, 2009 | HP Photosmart 3210 Printer
Ink on backside of paper
Same problem appeared with mine, but one month out of warranty. Black streak of varying intensity up to 6mmm wide on reverse of sheet being printed. Repeated reuse of the "Bottom Plate Cleaning" utility (60 to 70 times) did not solve the problem. Seems the problem lies with the pipe that carries waste ink from the purging dock to the middle of the machine where there is a large ink absorbent sponge. This pipe (or tube) blocks up and excess ink then builds up, eventually ending up on the back of the paper being printed. Canon support refuses to accept that this is a design fault, and claims that it is a "mechanical fault" , not their fault as the warranty has run out. There may be an 18-month warranty in parts of the US, but for the rest of us it is 12 months. Took the machine to the local Canon-authorised repair shop who charged EUR80 to unblock the pipe. There was no breakage or other mechanical fault. It will block up again, and there is nothing you can do about it - just grin and pay the repairman. It is amazing that a defective design such as this is allowed to be offered in the shops.
Jun 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
