Question about Toshiba Satellite A85-S107 Notebook
My Toshiba laptop won't boot. fan starts but nothing on screen, boot CD doesnt work, F12 doesnt do anything. any ideas?
    President:
  • 3,085 Answers
Toshibas are notorious for having bad INTERNAL power supplies.
I suspect it in your laptop
Posted on Nov 18, 2009
I can't get nothing on my screen. Once I turn it on it goes to the toshiba innovention page. And at the bottom of page it say something about. F-2 or f-12
You have a BIOS error but before adjusting anything, make sure there is no USB things connected or LAN cables plugged in and no cd in the player and re boot it.
If the choice screen of F2 or F12, press F2 and select default settings.
Re boot again. That should fix it.
Jan 02, 2011 | Toshiba Satellite L455DS5976 Notebook
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
Oct 08, 2009 | Toshiba Sattelite A105-S2071 Notebook
Toshiba A105 will not boot up even with cd and f12
its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
Jan 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite A85-S107 Notebook Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
